This chapter shows the list of Cash Flow Edit Error messages.
Topics:
· List of Cash Flow Edit Error messages
Error Code |
Error Condition |
Assignment |
Error Level |
Warning |
Description/Purpose |
Edit Priority |
9100 |
If ((AMRT_TYPE_CD <> 700 or (AMRT_TYPE_CD = 700 and AMRT_TERM <> 0)) and AMRT_TERM (in days) < ORG_TERM (in days) |
Set AMRT_TERM equal to ORG_TERM, AMRT_TERM_MULT = ORG_TERM_MULT |
2 |
Org Term > Amrt Term |
Amortization term can only be equal to zero on Non/Amortizing instruments |
9102 |
CUR_GROSS_RATE < 0 |
message only: Current Gross Rate < 0 |
1 |
Current gross rate must not be negative |
9103 |
CUR_NET_RATE < 0 |
message only: Current Net Rate < 0 |
1 |
Current net rate must not be negative |
9104 |
ACCRUAL_BASIS_CD <1 or >7 |
ACCRUAL_BASIS_CD equal to '3'. |
2 |
Invalid Accrual Basis Cd |
Accrual basis code must be between 1 and 7 inclusively |
9105 |
AMRT_TYPE_CD (<= 999 and not equal to 100, 200, 400, 500,600, 700, 710, 800, 801, 802, 820,830,840,850 or 999) or >99999 |
Set AMRT_TYPE_CD equal to '700'. |
2 |
Invalid Amortization Type defaulted to 700 |
Checks that amortization type codes are either in the user-defined range or that they are a valid OFSA code. |
9106 |
AMRT_TERM_MULT not equal to D, M, or Y |
AMRT_TERM_MULT = 'M' |
2 |
Invalid AMRT_TERM_MULT |
Checks for valid amortization term multipliers |
9107 |
NEG_AMRT_EQ_MULT not equal to D, M, or Y |
NEG_AMRT_EQ_MULT = 'M'. |
2 |
Invalid NEG_AMRT_EQ_MULT |
Checks for valid Neg.Amortization Eq.Multipliers |
9108 |
(NEG_AMRT_LIMIT >=200)or(NEG_AMRT_LIMIT < 0) and AMRT_TYPE_CD = 600 |
Set NEG_AMRT_LIMIT equal to 0. |
2 |
Invalid NgAm Limit |
Neg Am limit value does not fall in a valid range. (Neg Am instruments only) |
9109 |
ORG_TERM_MULT not equal to D, M, or Y |
ORG_TERM_MULT = 'M' |
2 |
Invalid ORG_TERM_MULT |
Checks for valid Original term multipliers |
9110 |
If AMRT_TYPE_CD = 600 and PMT_CHG_FREQ < 0 |
PMT_CHG_FREQ equal to 0 |
2 |
Invalid Pmt Chg Frq |
frequency cannot be negative (Neg Am instrument only) |
9111 |
PMT_CHG_FREQ_MULT not equal to D, M, or Y |
PMT_CHG_FREQ_MULT equal to 'M'. |
2 |
Invalid PMT_CHG_FREQ_MULT |
Checks for valid payment change frequency multipliers |
9112 |
PMT_FREQ_MULT not equal to D, M, or Y |
PMT_FREQ_MULT = 'M' |
2 |
Invalid PMT_FREQ_MULT |
Checks for valid payment frequency multipliers |
9114 |
RATE_CHG_RND_CD <0 or >4 |
RATE_CHG_RND_CD equal to '0'. |
2 |
Invalid Rate Chg Rnd Cd |
Rate change round code must be between 0 and 4 |
9115 |
RATE_SET_LAG_MULT not equal to D, M, or Y |
RATE_SET_LAG_MULT equal to 'M'. |
2 |
Invalid RATE_SET_LAG_MULT |
Checks for valid rate set lag multipliers |
9117 |
REPRICE_FREQ_MULT not equal to D, M, or Y |
REPRICE_FREQ_MULT = 'M'. |
2 |
Invalid REPRICE_FREQ_MULT |
Checks for valid reprice frequency multipliers |
9118 |
RATE_CHG_RND_FAC < 0 or RATE_CHG_RND_FAC > 1 |
Set RATE_CHG_RND_FAC equal to 0. |
2 |
Invalid Rt Chg Rnd Fact |
Rate change round factor must be a percentage |
9119 |
MATURITY_DATE < NEXT_PAYMENT_DATE |
MATURITY_DATE = NEXT_PAYMENT_DATE + ((REMAIN_NO_PMTS_C -1)*PMT_FREQ) |
2 |
Mat Dt < Next Pmt Dt |
The maturity date can not be before the next payment date |
9120 |
NEG_AMRT_EQ_FREQ < 0 and AMRT_TYPE_CD = 600 |
NEG_AMRT_EQ_FREQ equal to 0. |
2 |
NegAmEqFrq < 0 |
Neg Am Equalization frequency cannot be negative (Neg Am instruments only) |
9121 |
If AMRT_TYPE_CD = 600 and NEG_AMRT_EQ_FREQ > 0 and NEG_AMRT_EQ_DATE <= MAX(ORIGINATION_DATE,AS_OF_DATE) |
Set NEG_AMRT_EQ_DATE equal to NEXT_REPRICE_DATE |
2 |
NgAm Eq Dt < Org Dt |
Neg Am equalization date is less than origination date (future origination) or less than the as-of-date (past origination) (Neg am instrumented only) |
9123 |
AS_OF_DATE > ORIGINATION_DATE and AS_OF_DATE >= NEXT_PAYMENT_DATE |
NEXT_PAYMENT_DATE equal to AS_OF_DATE + 1 day. |
2 |
Next Pmt Dt < As of Dt |
The next payment date is less than as-of-date (past origination case) As of Date can not be greater than the origination date and greater than the next payment date. |
9124 |
ORIGINATION_DATE >= AS_OF_DATE and ORIGINATION_DATE >= NEXT_PAYMENT_DATE |
NEXT_PAYMENT_DATE = ORIGINATION_DATE + 1 day |
2 |
Next Pmt Dt < Org Dt |
Next payment date is less than origination date (future origination case) |
9125 |
ORIGINATION_DATE <= AS_OF_DATE and NEXT_REPRICE_DATE <= AS_OF_DATE and REPRICE_FREQ > 0 |
NEXT_REPRICE_DATE equal to AS_OF_DATE + 1 day. |
2 |
Next Repr Dt < As of Dt |
Next reprice date is less than as-of-date (past origination case) |
9126 |
ORIGINATION_DATE > AS_OF_DATE and NEXT_REPRICE_DATE < ORIGINATION_DATE and REPRICE_FREQ > 0 |
Set NEXT_REPRICE_DATE equal to ORIGINATION_DATE + 1 day |
2 |
Next Repr Dt < Org Dt |
Next reprice date is less than the origination date (future origination case) |
9127 |
ORG_PAYMENT_AMT = 0 and PMT_DECR_LIFE > 0 |
Set PMT_DECR_LIFE equal to 0. |
2 |
Org Pmt=0, Pmt Dec Lf<>0 |
Payment decrease life is expressed as a percent of a zero original payment. (Neg Am instruments only) |
9128 |
ORG_PAYMENT_AMT = 0 and PMT_INCR_LIFE > 0 |
Set PMT_INCR_LIFE equal to 0. |
2 |
Org Pmt=0, Pmt Incr Lf<>0 |
Payment increase life is expressed as a percent of a zero original payment. (Neg Am instruments only) |
9129 |
ORG_TERM <> calculated original term within 45 days or ORG_TERM = 0 |
Set ORG_TRM = calculated original term |
2 |
Org Term<>Mat Dt - Org Dt |
The original term should equal the time between the origination date and the maturity date. |
9130 |
(ORIGINATION_DATE < 01/01/1950) or (ORIGINATION_DATE > 01/01/2099) |
Set ORIGINATION_DATE = 01/01/1950. |
2 |
Orig. Dt < 01/01/1950 |
Origination date must be acceptable |
9131 |
PMT_FREQ > calculated original term |
PMT_FREQ equal to calculated original term |
2 |
Payment Freq > Org Term |
Payment frequency cannot be greater than the original term. |
9132 |
(CUR_PAYMENT < 0 and CUR_PAR_BAL > 0) or (CUR_PAYMENT > 0 and CUR_PAR_BAL < 0) |
Set CUR_PAYMENT equal to 0. |
2 |
Pmt, bal opposite signs |
Current payment and current balance can not have opposite signs |
9133 |
If AMRT_TYPE_CD = 600 and PMT_CHG_FREQ > 0 and AS_OF_DATE > PMT_ADJUST_DATE |
PMT_ADJUST_DATE = NEXT_REPRICE_DATE |
2 |
Pmt Adj Dt < As of Dt |
Neg Am equalization date is less than the as-of-date (past origination) (Neg am instrumented only |
9134 |
If AMRT_TYPE_CD = 600 and PMT_CHG_FREQ > 0 and AS_OF_DATE < PMT_ADJUST_DATE and PMT_ADJUST_DATE < ORIGINATION_DATE |
2 |
Pmt Adj Dt < Org Dt |
The payment adjustment date is less than origination date (future origination) (Neg am instrumented only) |
9135 |
PMT_FREQ <= 0 and ORIGINATION_DATE <= AS_OF_DATE and MATURITY_DATE > AS_OF_DATE and ORIGINATION_DATE > AS_OF_DATE and MATURITY_DATE > ORIGINATION_DATE |
NEXT_PAYMENT_DATE = MATURITY_DATE and ORG_TERM = calculated original term and PMT_FREQ = calculated original term and REMAIN_NO_PMTS_C = 1 |
2 |
Pmt Freq <= 0, Trm Assumed |
Payment frequency is less than or equal to zero, and both maturity date and origination date are valid dates and can be used to calculate payment frequency. |
9135 |
PMT_FREQ <= 0 and ORIGINATION_DATE <= AS_OF_DATE, MATURITY_DATE <= AS_OF_DATE but NEXT_PAYMENT_DATE > AS_OF_DATE or ORIGINATION_DATE > AS_OF_DATE, MATURITY_DATE < ORIGINATION_DATE,but NEXT_PAYMENT_DATE > ORIGINATION_DATE |
MATURITY_DATE = NEXT_PAYMENT_DATE and ORG_TERM = calculated original term and PMT_FREQ = calculated original term and REMAIN_NO_PMTS_C = 1 |
2 |
Pmt Freq <= 0 ,Trm Assumed |
Payment frequency is less than or equal to zero and maturity date is invalid, but next payment date can be used to calculate a valid payment frequency |
9135 |
PMT_FREQ <= 0 and ORIGINATION_DATE <= AS_OF_DATE, MATURITY_DATE <= AS_OF_DATE, and NEXT_PAYMENT_DATE <= AS_OF_DATE or ORIGINATION_DATE > AS_OF_DATE, and both MATURITY_DATE and NEXT_PAYMENT_DATE less than ORIGINATION_DATE |
MATURITY DATE = AS OF DATE + 1 day and NEXT PAYMENT DATE = AS OF DATE + 1 day and ORG TERM = calculated original term and PMT_FREQ = calculated original term and REMAIN_NO_PMTS_C = 1. |
2 |
Payment frequency less than or equal to zero and all dates which can be used to calculate payment frequency is in the past |
9136 |
PMT_INCR_CYCLE < 0 |
Set PMT_INCR_CYCLE equal to 0. |
2 |
Pmt Incr Cycle < 0 |
Payment increase cycle cannot be less than zero (Neg Am instruments only) |
9138 |
RATE_CAP_LIFE < CUR_GROSS_RATE and RATE_CAP_LIFE <> 0 and CUR_GROSS_RATE <> 0 and TEASER_END_DATE < AS_OF_DATE |
Set RATE_CAP_LIFE equal to CUR_GROSS_RATE. |
1 |
Rt Cap Lf < Cur Gross Rt |
Current gross rate is greater than the rate cap life |
9139 |
RATE_CAP_LIFE < CUR_NET_RATE and RATE_CAP_LIFE <> 0 |
message only: Rt Cap Life < Cur Net Rt |
1 |
Current net rate is greater than the rate cap |
9140 |
RATE_CHG_MIN < 0 |
Set RATE_CHG_MIN equal to 0. |
2 |
Rate Chg Min < 0 |
Minimum rate change can not be negative |
9141 |
RATE_DECR_CYCLE < 0 |
RATE_DECR_CYCLE equal to 0. |
2 |
Rate Decr Cycle < 0 |
Rate decrease cycle must not be negative |
9143 |
RATE_FLOOR_LIFE > CUR_GROSS_RATE and CUR_GROSS_RATE <> 0 and TEASER_END_DATE < AS_OF_DATE |
Set RATE_FLOOR_LIFE equal to CUR_GROSS_RATE. |
1 |
Rt Floor Lf > Cur Grss Rt |
Current gross rate is less than the rate floor |
9144 |
RATE_FLOOR_LIFE > CUR_NET_RATE |
message only: Rt Floor Lf > Cur Net Rt |
1 |
Rate floor life must not be greater than the current net rate |
9145 |
RATE_INCR_CYCLE < 0 |
RATE_INCR_CYCLE equal to 0. |
2 |
Rate Incr Cycle < 0 |
Rate increase cycle can not be less than 0 |
9147 |
REMAIN_NO_PMTS_C < 1 |
2 |
Rem No Pmts < 1 |
There has to be at least 1 payment left |
9148 |
RATE_SET_LAG < 0 |
RATE_SET_LAG = 0 |
2 |
Set Lag < 0 |
Rate set lag can not be negative |
9152 |
ORG_PAR_BAL < CUR_PAR_BAL and AMRT_TYPE_CD =710 |
message only: OrgParBal < CurParBal |
1 |
Org Par Bal < Cur Par Bal |
The original balance on the rule of 78's instruments should not be greater than the current balance |
9153 |
REPRICE_FREQ = 0 and (AMRT_TYPE_CD = 500 or AMRT_TYPE_CD = 600) |
message only: AdjAmrtType, ReprFrq=0 |
1 |
Reprice frequency denotes fixed on adjustable amortization types (Conventional Adjustable and Adjustable Neg Am) |
9154 |
REPRICE_FREQ <> 0 and LAST_REPRICE_DATE > NEXT_REPRICE_DATE |
LAST_REPRICE_DATE = NEXT_REPRICE_DATE minus REPRICE_FREQ |
2 |
LastReprDt>NextReprDt |
Last reprice date is greater than the next reprice date |
9155 |
IF INTEREST_RATE_CD < 0 or INTEREST_RATE_CD > 99999 |
INTEREST_RATE_CD = 0 |
2 |
Int Rt Code out of range |
Interest rate code must be within a valid range |
9157 |
T_RATE_INT_RATE_CD < 0 or T_RATE_INT_RATE_CD > 99999 |
T_RATE_INT_RATE_CD = 99999 |
2 |
T_ Rt Int Rt Cd out of rng |
T rate interest rate code must be within a valid range. |
9158 |
If CUR_BOOK_BAL <> (CUR_PAR_BAL + DEFERRED_CUR_BAL) |
Warning Only |
1 |
CurBkBl <> ParBl + Def Bl |
Current book balance should equal the current par balance plus the deferred current balance |
9159 |
CUR_NET_PAR_BAL_C - CUR_PAR_BAL * ( 1 - PERCENT_SOLD/100) >.001 |
Warning |
1 |
NetParBl<>Com ptd NetParBl |
Current net par balance should reflect the bank-owned portion of the current gross balance |
9160 |
If AMRT_TYPE_CD = 600 and PMT_DECR_CY < 0 |
PMT_DECR_CY = 0 |
2 |
Payment Decrease Cycle =0 |
Payment decrease cycle cannot be less than zero (Neg Am instruments only) |
9161 |
If AMRT_TYPE_CD = 600 and PMT_DECR_LF < 0 |
2 |
PmtDecrLf<0 for Adj NegAm |
Payment decrease life cannot be less than zero (Neg Am instruments only) |
9162 |
If AMRT_TYPE_CD = 600 and PMT_DECR_LF <> 0 and CUR_PAYMENT < ORG_PAYMENT_AMT * (1 - PMT_DECR_LF/100) |
Warning Only |
1 |
Cur Pmt < Life Pay Floor |
The current payment is less than the minimum payment amount (Neg Am instruments only) |
9163 |
If AMRT_TYPE_CD = 600 and PMT_INCR_LF < 0 |
2 |
PmtIncrLf<0 for Adj NegAm |
Payment increase life cannot be less than zero (Neg Am instruments only) |
The error level for the Cash Flow Edit rules:
Severity 0 is a warning, Severity 1 is Significant (but a default may be used while processing), and Severity 2 is Critical and the processing of the record may be skipped.
