Routes
GET
REST URL - https://<IP>:<port>/provapi/routes SUPPORTED METHOD - GET HEADER - AuthorizationSample Request Body -Not required
Sample Response Body
[ { "accountId": 0, "agentIdEditableFlag": byte, "application": "string", "codecProfileId": 0, "completedEditableFlag": byte, "deleteRecordingPermission": byte, "downloadRecordingPermission": byte, "forceRpdd": 0, "label": "string", "maximumNumberOfPorts": 0, "minimumStorageDays": 0, "notesEditableFlag": byte, "numberOfBurstPorts": 0, "percentToRecord": 0, "playbackRecordingPermission": byte, "priority": 0, "ratingEditableFlag": byte, "recSegmentationState": byte, "recordSaveDTMF": byte, "recordingEnabled": byte, "routeId": 0, "routePattern": "string", "routeType": byte, "storeDtmfSetting": byte, "videoAccessEnabled": byte, "videoRecordingEnabled": byte, "virtualRoutePattern": "string" } ]
Example
[ { "routeId": 4, "accountId": 1, "routeType": 1, "routePattern": "%", "virtualRoutePattern": "%DNIS%", "label": "", "priority": 5, "application": "conference", "recordingEnabled": 1, "recSegmentationState": 1, "percentToRecord": 100, "forceRpdd": 0, "codecProfileId": 1, "storeDtmfSetting": 1, "videoRecordingEnabled": 1, "videoAccessEnabled": 0, "agentIdEditableFlag": 0, "ratingEditableFlag": 0, "completedEditableFlag": 0, "notesEditableFlag": 0, "recordSaveDTMF": "#", "minimumStorageDays": 90, "maximumNumberOfPorts": 24, "numberOfBurstPorts": 6, "playbackRecordingPermission": 1, "downloadRecordingPermission": 1, "deleteRecordingPermission": 1 } ]
POST
REST URL - https://<IP>:<port>/provapi/routes SUPPORTED METHOD - POST HEADER - AuthorizationPath Parameter - No parameters
Sample Request Body - Create a file with the following data to be
imported:
- route_type
- route_pattern
- virtual_route_pattern
- label
- priority
- account_name
- percent_to_record
- recording_enabled
- default_recording_type
- agent_id_editable_flag
- rating_editable_flag
- completed_editable_flag
- notes_editable_flag
- application
- maximum_number_of_ports
- number_of_burst_ports
- minimum_storage_days
Sample Output Response
Routes imported successfully
POST
REST URL - https://<IP>:<port>/provapi/routes SUPPORTED METHOD - POST HEADER - AuthorizationSample Request Body
"accountId": 0,
"label": "string",
"priority": 0,
"routeType": byte,
{ "accountId": 0, "agentIdEditableFlag": byte, "application": "string", "codecProfileId": 0, "completedEditableFlag": byte, "deleteRecordingPermission": byte, "downloadRecordingPermission": byte, "forceRpdd": 0, "label": "string", "maximumNumberOfPorts": 0, "minimumStorageDays": 0, "notesEditableFlag": byte, "numberOfBurstPorts": 0, "percentToRecord": 0, "playbackRecordingPermission": byte, "priority": 0, "ratingEditableFlag": byte, "recSegmentationState": byte, "recordSaveDTMF": byte, "recordingEnabled": byte, "routeId": 0, "routePattern": "string", "routeType": "string", "storeDtmfSetting": byte, "videoAccessEnabled": byte, "videoRecordingEnabled": byte, "virtualRoutePattern": "string" }
Sample Input Body
"accountId": 1,
"label": "New Route",
"priority": 1,
"routePattern": "%%",
"routeType": 1,
"virtualRoutePattern": "%%"
{ "routeId": 5, "accountId": 1, "routeType": 1, "routePattern": "%%", "virtualRoutePattern": "%%", "label": "New Route", "priority": 1, "application": "conference", "recordingEnabled": 1, "recSegmentationState": 0, "percentToRecord": 100, "forceRpdd": 0, "codecProfileId": 1, "storeDtmfSetting": -1, "videoRecordingEnabled": 1, "videoAccessEnabled": 1, "agentIdEditableFlag": 0, "ratingEditableFlag": 0, "completedEditableFlag": 0, "notesEditableFlag": 0, "recordSaveDTMF": "#", "minimumStorageDays": 90, "maximumNumberOfPorts": 24, "numberOfBurstPorts": 6, "playbackRecordingPermission": 1, "downloadRecordingPermission": 1, "deleteRecordingPermission": 1 }
DELETE
REST URL - https://<IP>:<port>/provapi/routes/{routeID}
SUPPORTED METHOD - DELETE
PATH PARAMETER - routeID
Sample Request Body - Not Required
Route with ID <routeID> is deleted
Example
Route with ID 3 is deleted
GET
Sample Request Body - Not required
Example
PATCH
SUPPORTED METHOD - PATCH
PATH PARAMETER - routesID
Sample Request Body - Any permissible key values for update
Sample Input Body
"completedEditableFlag": 1,
"label": "Sample label"
{ "routeId": 4, "accountId": 1, "routeType": 1, "routePattern": "%", "virtualRoutePattern": "%DNIS%", "label": "Sample label", "priority": 5, "application": "conference", "recordingEnabled": 1, "recSegmentationState": 1, "percentToRecord": 100, "forceRpdd": 0, "codecProfileId": 1, "storeDtmfSetting": 1, "videoRecordingEnabled": 1, "videoAccessEnabled": 0, "agentIdEditableFlag": 0, "ratingEditableFlag": 0, "completedEditableFlag": 1, "notesEditableFlag": 0, "recordSaveDTMF": "#", "minimumStorageDays": 90, "maximumNumberOfPorts": 24, "numberOfBurstPorts": 6, "playbackRecordingPermission": 1, "downloadRecordingPermission": 1, "deleteRecordingPermission": 1 }
GET
REST URL - https://<IP>:<port>/provapi/routes/{routeID}/routeGroup
[ { "routeMasterId": 0, "routeMemberId": 0, "routePattern": "string", "virtualRoutePattern": "string" } ]
Example
[ { "routeMemberId": 2, "routeMasterId": 5, "routePattern": "$", "virtualRoutePattern": "$" } ]
POST
Sample Request Body
"virtualPattern": "string"
Sample Input Body
"virtualPattern": "%%"
{ "routeMemberId": 3, "routeMasterId": 5, "routePattern": "%$", "virtualRoutePattern": "%$" }
DELETE
REST URL - https://<IP>:<port>/provapi/routes/{routeID}/routeGroup/{memberID}
PATH PARAMETER - routeID, memberID
Member Route Successfully RemovedExample
