REST API Sample Workflow
- POST
/authenticate
Authentication is the initial process for all API requests and is a mandatory step. Enter the required username and password to access the authentication token. These are the same credentials used to access the Dashboard.
Ensure you have a valid token before accessing the API. Authentication tokens are only valid for a certain amount of time. - GET
/accounts
Provides a list of accounts for the signed in user only.
- POST
/accounts
Provides the required information to create an account. Account details are provided by the user except accountId, which is generated by the system.
- POST
/accounts/search
Search any account by providing valid fields in the request.
- POST
/accounts/upload
Import a CSV file with a list of accounts.
- DELETE
/accounts/
Deletes the specified account. You can access a list of accounts using the GET /accounts API. Once you delete an account it is permanently deleted and cannot be retrieved.
- GET
/accounts/{accountId}
Get account details for the specified account. You can access a list of accounts using the GET /accounts API.
- PATCH
Update the specified account with this patch. You can access a list of accounts using the GET /accounts API.
- PUT
Update the data for the specified account. You can access a list of accounts using the GET /accounts API.
- PATCH
/accounts/{accountId}/routes
Archive all of the recordings for the specified account in the provided location.
- GET
Provides you with the routes list for the account. You can access a list of accounts using the GET /accounts API.
- GET
/codecProfile
Provides a list of codecProfiles.
- POST
/codecProfile
Provides the required information to create the codecProfile.
- PUT
/codecProfile/codecMapEntry/{codecMapId}/recordingFormat/{recordingFormatId}
Updates recording formats. Use the GET /codecProfile/codecProfileName/{codecProfileName} API to retrieve the codec map ID and Recording format ID. Use the GET /codecProfile/transmissionCodec API to retrieve transmission codecs.
- GET
Retrieves the details of the recording format profile. Provides the list of transmission codecs and recording format set for each of the transmission codecs.
- GET
/codecProfile/recordingFormat
Provides a list of supported recording formats.
- GET
Provides a list of transmission codecs.
- DELETE
/codecProfile/{codecProfileId}
Deletes a specified recording. Use the GET /codecProfile/codecProfileName/{codecProfileName} API to retrieve the codec profile ID.
- GET
/codecProfile/{codecProfileId }
Provides you with the details of the specified codec profile. Use the GET /codecProfile/codecProfileName/{codecProfileName} API to retrieve the codecProfile ID.
- PUT
Updates the details of the specified codecProfile. Use the GET /codecProfile API to retrieve a list of codecProfiles.
- GET
/routes
Provides a list of routes in the system.
- POST
/routes
Provides the required information to create a route.
- POST
/routes/search
Search any route by providing valid fields in the request.
- POST
/routes/upload
Import a CSV file with a list of routes.
- DELETE
/routes/{routeId}
Delete the specified route from the system. Use the GET /routes API to retrieve a list of routes.
- GET
/routes/{routeId}
Provides you with the details for the specified route. Use the GET /routes API to retrieve a list of routes.
- PATCH
/routes/{routeId}
Update the specified route with this patch. Use the GET /routes API to retrieve a list of routes.
- PUT
/routes/{routeId}
Update the data for the specified route. Use the GET /routes API to retrieve a list of routes.
- GET
/routes/{routeId}/routeGroup
Provides a list of route groups associated with the specified route. Use the GET /routes API to retrieve a list of routes.
- POST
Creates a specific routeGroup for a particular route. Use the GET /routes API to retrieve a list of routes.
- DELETE
/routes/{routeId}/routegroup/{memberId}
Deletes a specified routeGroup. Use the GET /routes/{routeId}/routeGroup API to retrieve a list of routeGroups.
- GET /users
Provides a list of users.
- POST /users
Provides the required information to create a user.
- POST /users/upload
Import a CSV file with a list of users.
- GET
/users/userName/{userName}
Provides details of the specified user.
- DELETE
/users/{userID}
Deletes the specified user. Use the GET /users API to get the User ID.
- GET
/users/{userId}
Provides you with the details for the specified user. Use the GET /users API to retrieve a list of users.
- PATCH
/users/{userId}
Update the specified user with this patch. Use the GET /users API to retrieve a list of users.
- DELETE
/users/{userId}/userAccount/{accountId}
Deletes the specified user account. Use the GET /users API to retrieve a list of users. Use the POST /account/search API to get the account ID.
- PUT
Adds the specified user to the specified account. Use the GET /users API to retrieve a list of users. Use the POST /account/search API to get the account ID.
- PUT
/users/{userId}/userRoute/{routeId}
Adds the specified user to the specified route. Use the GET /users API to retrieve a list of users. Use the POST /routes/search API to get the route ID.
- DELETE
/users/{userId}/userRoute/{routeId)
Deletes the specified user from the specified route. Use the GET /users API to retrieve a list of users. Use the POST /routes/search API to get the route ID.
