Installing the ISR Software
This chapter provides the information and procedures you need to install the ISR components.
The
ISR runs on Oracle Linux
7 and uses yum to install and update RPM files.
The ISR has been tested with Oracle Linux only. Other Linux distributions have not been tested or verified.You must have Oracle Linux Releases 7.2 - 7.6 installed on your hardware prior to installing the ISR. Refer to the "Installation Prerequisites" section of this guide before proceeding.
You must install the
ISR components in the
following order:
- Index
- RSS
- Dashboard
- FACE API (optional)
The order in which you install the ISR components is very important. The installation does not work if you install the components in any order other than the order listed above.
