Troubleshooting
Issue:
If the
showmount command fails:
$ showmount 10.138.217.89 clnt_create: RPC: Port mapper failure - Unable to receive: errno 113 (No route to host)Solution:
This is likely due to a firewalld configuration problem. Verify your configuration.
Issue:
You cannot write to share.
$ touch tmpshare/foo.txt touch: cannot touch `tmpshare/foo.txt': Permission deniedSolution:
Update the permissions by changing the mode/ownership of the share on the NFS server using the chmod and/or chown commands.
