Deploying ISR FACE API
The ISR FACE API is deployed the same way as the other ISR components. The ISR FACE API is commonly deployed on an Oracle Linux 7 VM and has the same prerequisites as the other ISR components, described in "Installation Prerequisites".
Installing ISR FACE API
By default, FACE API is configured to handle HTTP requests over SSL, but you must perform the following steps to complete the initial configuration.
During the installation process, you will be asked to provide and/or verify the users, passwords, and interfaces you created during the Oracle Linux installation.To install the ISR FACE API:
