Administration – Interfaces – Property Interfaces – Property Interfaces
The following are additional setup options for the DLS type property interface for enhanced room key generation on the General Information panel.
Send Valid Start Date / Time — When this check box is selected, the Valid Start Date and Valid Start Time fields appear on the Create Key screen and the Room Keys screen. These enable you to set the key activation date and time.
Limit Additional Number of Rooms To — When the Allow Multiple Room Selection for Keys check box is selected, the Limit Additional Number of Room To field is available. This field limits the number of additional rooms you can select or manually enter in the Additional Rooms field.
Parent topic: Enhanced Room Key Generation
