1 About Oracle Financial Services Customer Screening
Oracle Financial Services Customer Screening (OFS CS) enables organizations to effectively and efficiently screen their customers so that they can successfully meet anti-bribery, anti-corruption, export control, and other legal regulations as well as to meet anti-money laundering and counter-terrorist financing legislations. Screening customers enables organizations to keep track of and avoid the risk of being exposed to suspicious or sanctioned individuals and organizations.
Topics:
·        Process Flow for Administrator
·        Quick Tour of Customer Screening
·        Customer Screening Workflow
The system administrator can perform the required tasks and configurations in the following order. Optionally, you can also configure and execute pipelines on a new environment, and import or copy pipelines if you are moving data between environments.
The following figure illustrate process flow for Administrator
Description of the Process Flow for Administrator Workflow
The following table provides an overview of the tasks and the order to execute these tasks using the Customer Screening application. Click the links to read details of each task.
Table : Quick Tour of Customer Screening
Order
Tasks
Details and Documentation
1
Subscribe to the  Application
Subscribe to the application. For more information on the subscription process, see Getting Started with Oracle Financial Services Crime and Compliance Management Cloud Service.
2
Provision Users
Configure Security Management System (SMS) to create users, roles, and implement user authorization and authentication. For more information on provisioning users, see Setup your Cloud Account.
3
Manage User Groups, Roles, and Functions
Create user groups, create roles, map users to user groups, map user groups to roles, and map roles to functions. For more information on the steps involved, see Identity Management.
4
Configure Pipelines
·        Import the ready-to-use pipelines to the Customer Screening application, create a copy of the imported pipelines and save it as a new pipeline. For more information, see Importing Pipelines and Copying Pipelines.
·        Create new pipelines and configure the same as per your requirements. To create pipelines, see Creating Pipelines.
5
Perform Application Security Mapping
Create security attributes that allow or restrict access to users. For more information, see Oracle Financial Services Crime and Compliance Management Cloud Service Application Security.
6
Map Pipeline to Jurisdiction
Map a ready-to-use pipeline or add a new pipeline and map it to one or more jurisdictions. For more information, see Map Pipeline to a Jurisdiction and Entity Type.
7
Load Customer and Watch list Data using Batches
Run the FullLoadCustomer batch in the Schedule window to load data. For more information, see Scheduler Service.
8
Screen Customer and Watch list Records – Individual and Entity
Screen records against watch list data. Alerts are generated based on the matching rules and associated thresholds For more information, see Matching Rules Widget.
9
Generate Alert
Select the attribute which generates a re-alert based on the change in the attribute value. For more information, see Alert Decision widget.
10
Investigate Cases
Investigate and monitor cases. For more information, see Investigating Cases.
The following figure illustrates the Customer Screening workflow. Customer Screening Workflow
Description of the Customer Screening Workflow
Download Watch Lists and Loading Data to Elastic search/OpenSearch
NOTE:
You must migrate from Elastic search (ES) to OpenSearch (OS) while the Elastic Search-related components and processes continue to exist. Once you are migrated OS, the Elastic search pipelines will be completely removed. For More information on migrating from ES to OS, see OpenSearch Migration User Guide. For more information on OpenSearch, see OpenSearch.
The watch list widget downloads the watch list data by using the URL specified in the Watch List Management window in the Watchlist Management widget link to widgets section in pipeline designer. The URLs are ready-to-use and can be edited if required; the username and password must be entered only if required for the watch list. The watch list widget can download and ingest free and subscription-based watch lists for screening. You can also use private watch lists using the Private Watchlist window. Private watchlist supports upload and download of data. For more information, see Private Watch List.
·        To download the Office of Foreign Assets Control (OFAC), United Nations (UN), European Union (EU) and HM Treasury (HMT) watch list data and load it to ES/OS for matching:
§       ES- Run the OFACWatchlistLoad, UNWatchlistLoad, EUWatchlistLoad and HMTWatchlistLoad batch through the Scheduler Service.
§       OS - Run the WLOFACLoad, WLUNLoad, WLEULoad and WLHMTLoad batch through the Scheduler Service.
·        To download the WC watch list data and load it to ES/OS for matching:
§       ES - Run the WCStandardWatchlistLoad batch if you have a standard subscription, run the WCPremiumWatchlistLoad batch if you have a premium subscription, and run the WCPremiumPlusWatchlistLoad batch if you have a premium plus subscription. These batches are run through the Scheduler Service.
§       OS - Run the WLWCSTANDARDLoad batch if you have a standard subscription, run the WLWCPREMIUMLoad batch if you have a premium subscription. These batches are run through the Scheduler Service.
·        To download the DowJones data and load it to ES/OS for matching:
§       ES - Run the DJWWatchlistLoad. These batches are run through the Scheduler Service.
§        OS - Run the WLDJWLoad. These batches are run through the Scheduler Service.
·        To download the private watch list data and load it to ES/OS for matching:
§       ES - Run the PrivateWatchlistLoad batch through the Scheduler Service.
§       OS - Run the WLPRIVATELoad batch through the Scheduler Service.
Optionally, Financial Institutions with a large customer base can periodically load delta records of customer data and watch list data. Oracle's Customer Screening Cloud Service screens the delta records of customers and watchlist records without impacting the quality of the events generated.
·        To download the WC Delta Watch List Data and load it to ES/OS for matching:
§       ES - Run the WC Standard Watchlist Delta Load batch if you have a standard subscription, run the WC Premium Watchlist Delta Load batch if you have a premium subscription, and run the WC Premium Plus Watchlist Delta Load batch if you have a premium plus subscription. These batches are run through the Scheduler Service.
§       OS - Run the WLWCSTANDARDDeltaLoad batch if you have a standard subscription, run the WLWCPREMIUMDeltaLoadbatch if you have a premium subscription. These batches are run through the Scheduler Service.
·       To download the DowJones Delta Watch List Data and load it to ES/OS for matching:
§       ES - Run the DJWWatchlistDeltaLoad. These batches are run through the Scheduler Service.
§       OS - Run the WLDJWDeltaLoad. These batches are run through the Scheduler Service.
NOTE:
After migrating to OS, the watchlist batches executed in ES should be executed in OS.
The CustomerFullLoad batch must be executed after migrating to OS.
The CustomerDeltaLoad batch must be executed after one day.
Load Customer Data to Elastic search/OpenSearch
Use a predefined template to create an ES/OS index. The template has information on the data and analyzer types used in the JSON. It also describes the fields used in the JSON. ES/OS gives results in real-time. The matching service uses ES/OS to generate matches.
·        To load the data and load it to ES/OS for matching:
§       ES - Run the FullLoadCustomer batch in the Scheduler Service. For information on how to load data from the object store to staging and from staging to the business tables if the Anti-Money Laundering (AML) application is not deployed, see Using FCCM Data Loading Service.
§       OS - Run the CustomerFullLoad batch in the Scheduler Service. For information on how to load data from the object store to staging and from staging to the business tables if the Anti-Money Laundering (AML) application is not deployed, see Using FCCM Data Loading Service.
·        To load data for the object store to staging and staging to business tables if Anti-Money Laundering AML is not deployed, see Uploading Data Files.
·        To load Customer Delta Data and load it to ES/OS for matching:
§       ES - Run the DeltaLoadCustomer batch in the Scheduler Service.
§       OS- Run the CustomerDeltaLoad batch in the Scheduler Service.
Manage Pipelines
There are four ready-to-use pipelines: two pipelines are used for individual batch and real-time data and two pipelines are used for entity batch and real-time data. Within the pipelines are different matching configurations for SAN, PEP and EDD records which can be tuned depending on your risk appetite.
Matching configuration is set using the Matching Rules widget. Each widget defines a match configuration for a source (customer) and target (watch list). The source and target can be filtered. This is how we set the different matching configurations for entities and individuals. It can also be used for setting different configurations for jurisdictions and domains.
Each ruleset can contain multiple rules and the score given to an alert is the maximum of the individual rule scores. An alert is generated only if the score is above the ruleset threshold. Within a rule configuration, source and target attributes are defined along with the match type (exact match, fuzzy match, or date match)  and scoring method (Reverse Jaro Winkler, Jaro Winkler, Levenshtein). Each attribute level match has a threshold, below which the score is not considered, and a weightage. If the Must condition is set, then a match will not be created unless the score for that attribute is above the threshold.
To match the customer records with watch list data, run the IndividualScreening batch for an individual or EntityScreening batch for an entity in the Scheduler Service.
Generate Alerts or Re-alerts
After all the attribute level scores are calculated a weightage average score for the rule is calculated and check against the ruleset threshold to determine if an alert is to be created. The alert is created only if the customer data or watchlist data is new or significantly changed from the previous time it was screened. The Alert Decision widget is where attributes can be configured to determine if a change in the data or an increase in the score will create a new alert. Alerts are generated for each match that exceeds the rule threshold.
If there is a change in the record value (first name, last name, date of birth) or score, the alert is regenerated. The attributes which resulted in the re-alert is highlighted with a red box on the Event Details page for the re-alert. For more information on event details, see the Case Investigation User guide.
You can specify the attributes which generate a re-alert based on the value change or score change in the Alert Decision window. For more information on Alert Decision window, see Using Pipeline Designer guide.
Generate a Case
When one or more matches are recorded between a watch list and a customer record, a case is generated. The user can take a decision and decide if the alert is a false positive or a true match. If a new alert is generated, a new case is also generated in Enterprise Case Management (ECM).
To generate the case in ECM, run the ScreeningToCaseMgmt batch in the Scheduler Service.
Generation of Canned Reports
Canned Reports captures the following information which will show up after the Batch execution for every run:
·         Customers in Staging table
·         Customers pushed from staging table into Customer Screening tables
·         Alerts/events generated
·         Customers with non-hits
·         Cases created
For more information on accessing the Canned Reports, see View Reports for Download.
