Approving or Rejecting Timesheets
As a timesheet approval manager or delegate, you can approve or reject timesheets for resources for which you are responsible. Depending on your P6 EPPM Application settings, an email may be sent to other managers when you reject a timesheet.
To approve or reject timesheets:
  1. Click Approvals.
  2. On the Approvals navigation bar, select Timesheets.
  3. On the Timesheets page:
    1. Select Project Manager or Resource Manager from the Approving as list. Or, if you are a delegate, select the value from the list that best represents your current role.
    2. Click Action Required to view timesheets awaiting your input or All Timesheets to view all timesheets.
    3. Configure the options in the Filter dock to filter the list of timesheets if required.
    4. Select the timesheets you want to approve or reject. To select multiple timesheets, use Ctrl+click or Shift+click.
    5. To approve the selected timesheets, click Approve or, to reject the selected timesheets, click Reject.
Tips
Related Topics
About Timesheets
Working with Timesheets
Configuring Resources for Timesheets
Sending Email about Timesheets to Resources
Assigning a Project Manager Delegate for Timesheets
Assigning a Resource Manager Delegate for Timesheets
Timesheets Page
Copyright © 1999, 2024
Last Published Friday, July 26, 2024
