Assigning a Project Manager Delegate for Timesheets
If you are a project manager, you can assign a temporary delegate to process timesheets awaiting your approval while you are not able to process them yourself. For example, you might be on business travel or vacation, or the workload requires you to assign timesheet approval responsibility to others.
To assign a project manager delegate:
  1. Click Approvals.
  2. On the Approvals navigation bar, select Timesheets.
  3. On the Timesheets page:
    1. Select Project Manager from the Approving as list.
    2. Click Actions and select Assign Project Manager Delegate.
  4. In the Assign Project Manager Delegate dialog box:
    1. If more than one project is listed, select a project.
    2. Double click the delegate field, clickSelect, and select a user from the Select a User dialog box. Click OK.
    3. To activate the delegate's approval rights, select the check box for the project row where you need to designate a delegate.
    4. Click Apply.
    5. Repeat for each project that you want to assign to a delegate.
    6. Click OK.
Tips
When removing a delegate, the format of the message is:
<username> has removed your time approval delegate rights for the following projects: <project 1>, <project 2>, etc. Thank you for your assistance.
Related Topics
About Timesheets
Working with Timesheets
Configuring Resources for Timesheets
Approving or Rejecting Timesheets
Sending Email about Timesheets to Resources
Assigning a Resource Manager Delegate for Timesheets
Timesheets Page
Copyright © 1999, 2024
Last Published Friday, July 26, 2024
