Post actual amounts for a period
  1. Choose Tools, Store Period Performance.
    The Store Period Performance dialog box lists all open projects.
  2. Determine the projects you want to post actual amounts for, then double-click in the Financial Period column to select a financial period for each applicable project.
    When connected to a P6 Professional database: The Select Financial Period dialog box lists all financial periods defined in the financial period calendar assigned to the project.
    When connected to a P6 EPPM database: The Select Financial Period dialog box lists all financial periods defined for the financial period calendar in P6.
  3. Determine the projects you do not want to post actual amounts for, then clear the corresponding checkbox in the Selected column for each applicable project.
  4. Click Store Now.
    P6 Professional stores the Actual This Period values in the selected financial period for each project (regardless of the data date or Actual Start dates), then sets Actual This Period values to zero in anticipation of the next schedule update period.
Tips
Notes
When connected to a P6 EPPM database: To store period performance, you must have the appropriate project privileges as defined in P6.
Related Topics
Financial Periods of Calendar dialog box (P6 Professional Only)
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
