- Select the activity.
- Display Activity Details, then click the WPs & Docs tab.
- Select one or more work products or documents.
To display the WPs & Docs tab, click the Layout Options bar and choose Bottom Layout Options. In the Available Tabs section, select WPs & Docs, click , then click OK. - Click Remove, then click Yes.
