Remove work product and document assignments in the Work Breakdown Structure window
  1. Select the WBS element.
  2. Display WBS details, then click the WPs & Docs tab.
  3. Select one or more work products or documents.
    To display the WPs & Docs tab, right-click in the Details area and choose Customize WBS Details. In the Available Tabs section, select WPs & Docs, click , then click OK.
  4. Click Remove, then click Yes.
Tip
Related Topics
Display work breakdown structure details
Copyright © 1999, 2021
Last Published Monday, December 6, 2021
