Processing Authorizations and Deposits using an Integration Layer Process
Overview: Processing authorizations and deposits using an integration layer process allows you to send an Authorization Request XML Message (CWAuthorizationRequest) or Deposit Request XML Message (CWDepositRequest) to the service bureau via an integration layer process in Working with Integration Layer Processes (IJCT).
Note: Order Management System does not currently support any base integration using an integration layer job and the Authorization Request XML Message (CWAuthorizationRequest) or Deposit Request XML Message (CWDepositRequest). Please contact your Order Management System representative if you wish to create a custom integration using these messages.
In this topic:
• Authorization and Deposit XML Messages
• Authorization Request XML Message (CWAuthorizationRequest)
• Authorization Response XML Message (CWAuthorizationResponse)
• Deposit Request XML Message (CWDepositRequest)
• Deposit Response XML Message (CWDepositResponse)
The Authorization Request XML message is used to send the following information to the an external system when the Communication type field for the service bureau is Integration Layer:
• authorizations (online and batch) for credit cards, stored value cards transactions, and debit (Switch) cards
• register token for credit cards (see Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1))
• stored value card activations (see Activating a Stored Value Card for additional information)
• stored value card balance inquiries (see Stored Value Card Balance Inquiry (MSVB) for additional information)
• stored value card authorization reversals (see Stored Value Card Authorization Reversal for additional information)
The Mode attribute in this message indicates if the request is in online format or batch format.
• Online format: An Authorization Request message in online format sends one message to the service bureau for processing. This one message contains all of the information required to process an online transaction.
• Batch format: An Authorization Request message in batch format sends multiple message types to the service bureau for processing. These messages contain the information required to process a batch of transactions.
Note: Order Management System does not currently support any base integration using an integration layer job and the Authorization Request XML Message (CWAuthorizationRequest). Please contact your Order Management System representative if you wish to create a custom integration using this message.
Attribute Name |
Type |
Length |
Comments |
Online format: This element and its attributes is included in the Online message. Batch format: This element and its attributes display in the Header, Detail, Summary, Footer, Send, and Receive type messages. |
source |
alpha |
25 |
Identifies the source of the XML message. RDC indicates the message is from Order Management System. |
target |
alpha |
25 |
Identifies the target of the message. |
type |
alpha |
25 |
Identifies the type of information in the message. CWAuthorizationRequest indicates the message contains a card authorization request. |
resp_qmgr |
alpha |
48 |
Informational only. |
resp_q |
alpha |
48 |
mode |
alpha |
10 |
Indicates the mode of communication. Online indicates online format. Batch indicates batch format. |
type |
alpha |
10 |
Online format: This tag is not included in the Online message. Batch format: Indicates the type of message in the batch. Valid values: Header Detail Summary Footer Send Receive |
serviceID |
alpha |
3 |
Authorization service code. This is the ASV Auth service code field in the Authorization Service table. |
companyID |
numeric |
3 |
The company from where the authorization request was sent. This is the CMP Company field in the Authorization Service table. |
merchantID |
alpha |
20 |
The account number assigned by the service bureau to identify transmissions. The system uses the following hierarchy to determine the merchant ID number to send to the service bureau: • Merchant # from the CC Paytype Cross Ref table. • Merchant ID override from the Merchant ID Override table. • Merchant ID from the Authorization Service table. |
merchantSubID |
alpha |
10 |
The sub code required to sign on to the service bureau. This is the ASV Sub code field in the Authorization Service table. |
merchantName |
alpha |
20 |
The name of the service bureau. This is the ASV Charge description field in the Authorization Service table. |
merchantDivision |
numeric |
5 |
The merchant division defined by the service bureau. This is the ASE Merchant division field in the Authorization Service Ext table. |
chargeDescription |
alpha |
20 |
receivingCode |
alpha |
10 |
A code that identifies your company to the service bureau. This is the ASV Receiving code field in the Authorization Service table. |
startupInfo |
alpha |
10 |
Startup text that identifies your company to the service bureau. This is the ASV Start up info field in the Authorization Service table. |
signon |
alpha |
10 |
A code required to sign on to the service bureau. This is the ASV Signon field in the Authorization Service table. |
password |
alpha |
10 |
A password required by the service bureau. This is the ASV Password field in the Authorization Service table. |
presentersID |
alpha |
10 |
A code required to sign on to the service bureau. This is the ASV Presenter’s ID field in the Authorization Service table. |
pidPassword |
alpha |
10 |
A password required to sign on to the service bureau. This is the ASV PID password field in the Authorization Service table. |
submittersID |
alpha |
10 |
A code required to sign on to the service bureau. This is the ASV Submitter’s ID field in the Authorization Service table. |
sidPassword |
alpha |
10 |
A password required to sign on the service bureau. This is the ASV SID password field in the Authorization Service table. |
industryFormatCode |
alpha |
5 |
A code that is assigned by the authorization service to identify your company type (DBA number). This is the ASV Industry format code field in the Authorization Service table. |
addressVerfication Flag |
alpha |
3 |
Indicates whether the service bureau performs address verification to verify the customer’s address and card number. YES indicates the service bureau performs address verification. The system includes the bill to name and address in the authorization request. NO indicates the service bureau does not perform address verification. The system does not include the bill to name and address in the authorization request. This is the ASV Address verification field in the Authorization Service table. |
Not currently implemented. |
count |
numeric |
2 |
From the Authorization Service JCL table. |
id |
alpha |
2 |
From the JCL Seq # field and JCL Statement field in the Authorization Service JCL table. |
Online format: This element and its attributes is included in the Online message. Batch format: This element and its attributes is included in the Detail type message. |
companyID |
alpha |
3 |
The company from where the authorization request was sent. Online format: From the Company field in the On Line Authorization table. Batch format: From the CMP Company field in the CC Authorization Trans table. |
createDate |
numeric |
8 |
The date (in MMDDYYYY format) the authorization request was sent to the service bureau. |
orderType |
alpha |
8 |
Indicates the type of order, for example phone order or mail order, where the card requiring authorization is located. Mail = Mail order. Phone = Telephone order. Internet = Web order. Order Management System: • Looks at the value in the Internet order field in the Order Header table. If this field is set to I, the order is a web order. • Determines if the order type for the order matches the E-Commerce Order Type (G42) system control value. If the order type matches, the order is a web order. • Looks at the Forecasting order category field in the Order Type table. If this value is 1, the order is a mail order. If this value is 2, the order is a phone order. |
transactionType |
alpha |
10 |
Indicates if the transaction is a debit or credit. Debit indicates card sale. Credit indicates card credit/return. |
storeLocation |
alpha |
10 |
This is a future-use value. |
terminalID |
numeric |
15 |
Online format: From the OLA terminal # field in the On Line Authorization table; informational only. Batch format: This attribute does not display for batch authorizations. |
merchantReference |
numeric |
20 |
A unique number made up of the Order Management System company code + order number + order payment method sequence number + authorization sequence number. For stored value card activations, this is the company code + order number; the payment method sequence number and authorization sequence number are zero-filled. For stored value card balance inquiries, this is the company code + local workstation job number. Online format: From the Company, Order#, OPM Seq #, OLA Seq # fields in the OnLine Authorization table. Batch format: From the CMP Company, Order #, OPM Seq #, and AUH Seq # fields in the CC Authorization Trans table. |
transactionSeq Number |
numeric |
15 |
Online format: The online authorization transaction sequence number. From the OLA Trans seq # field in the OnLine Authorization table. Batch format: 000000000000000 defaults for batch transactions. |
orderID |
numeric |
8 |
The order number where the credit card payment method that requires authorization is located. Online format: From the Order # field in the OnLine Authorization table. Batch format: From the Order # field in the CC Authorization Trans table. For stored value card activations, from the Order # field in the Stored Value Card table. For stored value card reversals, from the Order # field in the Auth History SVC Reversal table. |
paymentID |
numeric |
2 |
The order payment method sequence number for this credit card payment method on the order. Online format: From the OPM Seq # field in the OnLine Authorization table. Batch format: From the OPM Seq # field in the CC Authorization Trans table. |
authID |
numeric |
3 |
The authorization sequence number for the credit card authorization request. Online format: From the OLA Seq # field in the OnLine Authorization table. Batch format: From the AUH Seq # field in the CC Authorization table. |
payCategory |
numeric |
15 |
A description of the pay category associated with the credit card authorization request. Credit card displays, indicating the credit card is associated with the credit card pay category. This is the description associated with the Pay category field defined for the credit card pay type in the Pay Type table. |
vendorPayment Method |
alpha |
5 |
The vendor paytype code associated with the credit card authorization request; this is the code the authorization service uses to identify a method of payment. SV displays for stored value card activations and reversals. From the CPC vendor paytype/code field defined for the credit card pay type in the CC Paytype Cross Ref table. |
cardType |
alpha |
10 |
Indicates the type of card being processed. Valid values: Credit card Stored Value Card Debit card |
actionCode |
alpha |
10 |
Indicates the action to take against the card being processed. Valid values: Activation = Stored value card activation. Balance = Stored value card balance inquiry. Authorization = Credit card, debit card, or stored value card authorization. Reversal = Stored value card authorization reversal. ReqToken = Register token; see Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1). |
startDate |
numeric |
4 |
The start date of the debit card being processed, in MMYY format. From the Start date field in the Order Payment Method table. |
issueNumber |
alpha |
2 |
The card issue number of the debit card being processed. From the OPM card issue # field in the Order Payment Method table. |
ccAccountNumber |
alpha |
20 |
The card number for the credit card payment method requesting authorization. From the OPM credit card number field defined for the credit card payment in the Order Payment Method table. If you use credit card encryption, the system decrypts the credit card number before sending it to the service bureau. See the Data Security and Encryption Guide on My Oracle Support (1988467.1) for an overview. If you use credit card tokenization, the setting of the tokenized tag defines whether the number in the ccAccountNumber tag is the actual credit card number or a token provided by an external tokenization service. |
expirationDate |
numeric |
4 |
The date the card requesting authorization expires. From the OPM expiration date field defined for the card in the Order Payment Method table. |
authAmountText |
numeric |
10.2 |
The transaction amount, including decimals. Note: Stored value cards are only allowed in US currency. In addition, stored value card balance inquiries, do not pass an amount. Online format: From the OLA auth amt field in the OnLine Authorization table. Batch format: From the Auth $ amt field in the CC Authorization Trans table. |
authAmount |
numeric |
10 |
The transaction amount, with implied decimals. Note: Stored value cards are only allowed in US currency. In addition, stored value card balance inquiries, do not pass an amount. Online format: From the OLA auth amt field in the OnLine Authorization table. Batch format: From the Auth $ amt field in the CC Authorization Trans table. For stored value card activations, from the Issue amount field in the Stored Value Card table. For stored value card reversals, from the Reversal amount field in the Auth History SVC Reversal table. |
currencyCode |
alpha |
3 |
The currency code used by the service bureau to define a currency. From the CUR currency code field in the Auth Service Currency table. |
CIDNumber |
numeric |
4 |
Credit Cards The card identification number defined for the card. Visa: If the number is 3 positions, the number is left-justified and blank filled. Diners Club: If the number is 3 positions, the system sends a leading space. Discover: If the number is 3 positions, the number is left-justified and blank filled. MasterCard: If the number is 3 positions, the number is left-justified and blank filled. American Express: If the number is 3 positions, the system sends a leading zero. From the OPM card security value field defined for the credit card payment method in the Order Payment Method table. Note: The card identification number is only available for online authorizations; once an order is accepted, the system removes the card identification number from the order, even if the order has not received an approved online authorization. Stored Value Cards The ID number assigned to the stored value card. Included only if an ID number is assigned to the card and a CID number does not exist. For activations, from the SVC ID # field in the Stored Value Card table. For authorizations, from the OPM SVC ID Storage field defined for the stored value card payment in the Order Payment Method table. |
CIDIndicator |
alpha |
1 |
The card identification indicator defined for the card, indicating if a CID number has been defined. Valid values: 1 = CID number is present on card. 2 = CID number is present on card, but is illegible. 9 = CID number is not present on card. From the OPM card security presence field defined for the credit card payment method in the Order Payment Method table. |
issuingBank |
alpha |
10 |
From the Issuing bank field defined for the payment method in the Order Payment Method table; this is a future-use value. |
checkAccountNumber |
alpha |
20 |
From the OPM Checking account field defined for the payment method in the Order Payment Method table; this is a future-use value. |
checkNumber |
numeric |
9 |
From the OPM Check number field defined for the payment method in the Order Payment Method table; this is a future-use value. |
routingNumber |
numeric |
9 |
From the OPM Routing number field defined for the payment method in the Order Payment Method table; this is a future-use value. |
ecommerceIndicator |
alpha |
3 |
Represents either: • An electronic commerce indicator code, received from a service bureau such as Visa’s Verified by Visa program or MasterCard’s SecureCode program, indicating the level of security provided for a credit card transaction placed over the internet. • A value indicating if the order was placed on a web storefront. Valid values are: - YES = The order was placed over the web storefront. - NO = The order was not placed over the web storefront. From the Ecomm Indic field in the Order Payment Method table. If this value is blank, from the E-Commerce indicator (Future use status 1) field in the Order Header table. |
authentication_value |
alpha |
40 |
A code received from an authentication service, such as Visa’s Verified by Visa program or MasterCard’s SecureCode program, indicating whether the card authentication password the cardholder provided was approved for the credit card. See Credit Card Authentication Service for more information. Updates the Authentication value field in the Order Payment Method table. |
Note: The system includes the following bill to information only if the Address verification field for the authorization service is selected. |
firstName |
alpha |
15 |
The first name of the bill to customer defined for the card requesting authorization. This is the: • First name field in the Customer Bill To table, or • NAM First name field in the Customer Sold To table. |
initial |
alpha |
1 |
The middle initial of the bill to customer defined for the card requesting authorization. This is the: • Initial field in the Customer Bill To table, or • NAM Initial field in the Customer Sold To table. |
lastName |
alpha |
25 |
The last name of the bill to customer defined for the card requesting authorization. This is the: • Last name field in the Customer Bill To table, or • NAM Last name field in the Customer Sold To table. |
companyName |
alpha |
30 |
The company name of the bill to customer defined for the card requesting authorization. This is the: • Company name field in the Customer Bill To table, or • NAM Company name field in the Customer Sold To table. |
suffix |
alpha |
3 |
The suffix of the bill to customer defined for the card requesting authorization. This is the: • Suffix field in the Customer Bill To table, or • NAM Suffix field in the Customer Sold To table. |
addressLine1 |
alpha |
32 |
The street address of the bill to customer defined for the card requesting authorization. This is the: • Street address field in the Customer Bill To table, or • NAM Street address field in the Customer Sold To table. |
addressLine2 |
alpha |
32 |
The second address line of the bill to customer defined for the card requesting authorization. This is the: • Address line 2 field in the Customer Bill To table, or • NAM Address line 2 field in the Customer Sold To table. |
addressLine3 |
alpha |
32 |
The third address line of the bill to customer defined for the card requesting authorization. This is the: • Address line 3 field in the Customer Bill To Extended table, or • Address line 3 field in the Customer Sold To Extended table. |
addressLine4 |
alpha |
32 |
The fourth address line of the bill to customer defined for the card requesting authorization. This is the: • Address line 4 field in the Customer Bill To table, or • Address line 4 field in the Customer Sold To table. |
apartment |
alpha |
10 |
The apartment for the address of the bill to customer defined for the card requesting authorization. This is the: • Apartment field in the Customer Bill To table, or • NAM Apartment field in the Customer Sold To table. |
city |
alpha |
25 |
The city for the address of the bill to customer defined for the card requesting authorization. This is the: • City field in the Customer Bill To table, or • NAM City field in the Customer Sold To table. |
state |
alpha |
2 |
The state for the address of the bill to customer defined for the card requesting authorization. This is the: • State field in the Customer Bill To table, or • NAM State field in the Customer Sold To table. |
zip |
alpha |
10 |
The zip code for the address of the bill to customer defined for the card requesting authorization. This is the: • Zip field in the Customer Bill To table, or • NAM Zip field in the Customer Sold To table. |
country |
alpha |
3 |
The country code for the address of the bill to customer defined for the card requesting authorization. This is the: • RPR country field in the Customer Bill To table, or • RPR country field in the Customer Sold To table. |
phoneType |
alpha |
12 |
Indicates the type of phone number (such as work or home) for the bill to customer defined for the card requesting authorization. This is a description of the: • CB# Phone # type field in the Customer Bill To Phone # table, or • CS# Phone # type field in the Customer Sold To Phone # table. |
phoneNumber |
alpha |
14 |
The phone number of the bill to customer defined for the card requesting authorization. This is the: • Phone field in the Customer Bill To Phone # table, or • Phone field in the Customer Sold To Phone # table. |
shiptoFirstName |
alpha |
15 |
The first name of the ship to customer on the order. This is the: • NAM First name field in the Order Ship To Address table, or • NAM First name field in the Customer Ship To table, or • NAM First name field in the Customer Sold To table. |
shiptoInitial |
alpha |
1 |
The middle initial of the ship to customer on the order. This is the: • NAM Initial field in the Order Ship To Address table, or • NAM Initial field in the Customer Ship To table, or • NAM Initial field in the Customer Sold To table. |
shiptoLastName |
alpha |
25 |
The last name of the ship to customer on the order. This is the: • NAM Last name field in the Order Ship To Address table, or • NAM Last name field in the Customer Ship To table, or • NAM Last name field in the Customer Sold To table. |
shiptoCompanyName |
alpha |
30 |
The company of the ship to customer on the order. This is the: • NAM Company name field in the Order Ship To Address table, or • NAM Company name field in the Customer Ship To table, or • NAM Company name field in the Customer Sold To table. |
shiptoSuffix |
alpha |
3 |
The suffix code of the ship to customer on the order. This is the: • NAM Suffix field in the Order Ship To Address table, or • NAM Suffix field in the Customer Ship To table, or • NAM Suffix field in the Customer Sold To table. |
shiptoAddressLine1 |
alpha |
32 |
The street address of the ship to customer on the order. This is the: • NAM Street address field in the Order Ship To Address table, or • NAM Street address field in the Customer Ship To table, or • NAM Street address field in the Customer Sold To table. |
shiptoAddressLine2 |
alpha |
32 |
The second address line of the ship to customer on the order. This is the: • NAM Address line 2 field in the Order Ship To Address table, or • NAM Address line 2 field in the Customer Ship To table, or • NAM Address line 2 field in the Customer Sold To table. |
shiptoAddressLine3 |
alpha |
32 |
The third address line of the ship to customer on the order. This is the: • Address line 3 field in the Order Ship To Address table, or • Address line 3 field in the Customer Ship To Extended table, or • Address line 3 field in the Customer Sold To Extended table. |
shiptoAddressLine4 |
alpha |
32 |
The fourth address line of the ship to customer on the order. This is the: • Address line 4 field in the Order Ship To Address table, or • Address line 4 field in the Customer Ship To Extended table, or • Address line 4 field in the Customer Sold To Extended table. |
shiptoApartment |
alpha |
10 |
The apartment for the address of the ship to customer on the order. This is the: • NAM Apartment field in the Order Ship To Address table, or • NAM Apartment field in the Customer Ship To table, or • NAM Apartment field in the Customer Sold To table. |
shiptoCity |
alpha |
25 |
The city for the address of the ship to customer on the order. This is the: • NAM City field in the Order Ship To Address table, or • NAM City field in the Customer Ship To table, or • NAM City field in the Customer Sold To table. |
shiptoState |
alpha |
2 |
The state for the address of the ship to customer on the order. This is the: • NAM State field in the Order Ship To Address table, or • NAM State field in the Customer Ship To table, or • NAM State field in the Customer Sold To table. |
shiptoZip |
alpha |
10 |
The postal code for the address of the ship to customer on the order. This is the: • NAM Zip field in the Order Ship To Address table, or • NAM Zip field in the Customer Ship To table, or • NAM Zip field in the Customer Sold To table. |
shiptoCountry |
alpha |
3 |
The country code for the address of the ship to customer on the order. This is the: • RPR Country field in the Order Ship To Address table, or • RPR Country field in the Customer Ship To table, or • RPR Country field in the Customer Sold To table. |
shiptoPhoneType |
alpha |
12 |
Indicates the type of phone number (such as work or home) for the ship to customer on the order. This is a description of the: • CT# Phone # type field in the Customer Ship To Phone # table, or • CS# Phone # type field in the Customer Sold To Phone # table. |
shiptoPhoneNumber |
alpha |
14 |
The phone number of the ship to customer on the order. This is the: • Phone field in the Customer Ship To Phone # table, or • Phone field in the Customer Sold To Phone # table. |
shiptoEmail |
alpha |
50 |
The e-mail address of the ship to customer on the order. This is the: • OSA Email address field in the Order Ship To Address table, or • CSH Email address field in the Customer Ship To table, or • Email field in the Customer Sold To table. |
tcVersion |
numeric |
5 |
dateOfBirth |
numeric |
8 |
socialSecurityNbr |
numeric |
9 |
shippingCost |
numeric |
8 |
orderCreateTime |
numeric |
6 |
itemClass |
alpha |
3 |
lastOrderDate |
numeric |
8 |
activeSinceDate |
numeric |
8 |
The date when the customer first placed an order, in MMDDYYYY format. This is the COH active since date field in the Customer Sold To Ord Hist table. |
alpha |
50 |
The email address of the bill to customer defined for the credit card requesting authorization. This is the CST email address field defined for the sold to customer on the order in the Customer Sold To table. |
authCode |
alpha |
16 |
The authorization number used to authorize the card. This is the Auth # field defined for the stored value card pay type on the order in the Authorization History table. This field is populated only when performing a stored value card authorization reversal; see Stored Value Card Authorization Reversal. |
tokenized |
alpha |
1 |
Defines whether the number in the ccAccountNumber is the actual credit card number or a token received from the authorization service during the credit card tokenization process. Valid values: Y = The number in the ccAccountNumber is a token. N = The number in the ccAccountNumber is the actual credit card number. The authorization service will attempt to replace the credit card number with a token and return the token in the Authorization Response XML Message (CWAuthorizationResponse). From the Tokenized field in the Order Payment Method table. The system includes the tokenized tag only if the pay type is eligible for tokenization. To be eligible for tokenization the Request token field for the authorization service defined for the pay type must be selected and the Pay category for the pay type must be Credit Card with the Card type set to C Credit Card. Available in: 2.0 (Order Management System version 5.0). |
Online format: This element and its attributes is not included in the Online message. Batch format: This element and its attributes is included in the Summary, Footer, Send, and Receive type messages. |
fileType |
alpha |
4 |
Indicates the type of information in the request. Valid values: AUTH = Authorization request. BILL = Deposit. SVCA = Stored value card activation request. SVCB = Stored value card balance inquiry request. SVCR = Stored value card authorization reversal request. |
merchantFileTrace |
alpha |
16 |
The next available number from the Batch Auth File Trace Number number assignment value. Note: The Batch Auth File Trace Number cannot be greater than 3 positions. |
createDate |
numeric |
8 |
debitAmount |
numeric |
11.2 |
The net sales amount for this batch of requests, with implied decimals. Included for the summary and footer batch messages. |
debitCount |
numeric |
9 |
The total count of sales records for this batch of authorization requests. Included for the summary and footer batch messages. |
creditAmount |
numeric |
11.2 |
The net refund amount for this batch of authorization requests, with implied decimals. Included for the summary and footer batch messages. |
creditCount |
numeric |
9 |
The total count of refund records for this batch of authorization requests. Included for the summary and footer batch messages. |
totalAmount |
numeric |
11.2 |
The total amount for this batch of authorization requests, with implied decimals. Included for the summary and footer batch messages. |
totalCount |
numeric |
9 |
The total count for this batch of authorization requests. Included for the summary and footer batch messages. |
testProductionFlag |
alpha |
4 |
Indicates whether the authorization request is processed in a live (production) environment or in a testing environment. TEST = testing environment. PROD = production environment. This is the ASE Test mode field from the Authorization Service table. |
For each Authorization Request Message sent to the service bureau, the service bureau sends an Authorization Response XML message to Order Management System.
• Online format: An Authorization Response message in online format sends one message to Order Management System for processing. This one message contains all of the information required to process an online authorization response.
• Batch format: An Authorization Response message in batch format sends multiple message types to Order Management System for processing. These messages contain the information required to process a batch of authorization responses. A separate detail type message is received for each authorization response in the batch.
Attribute Name |
Type |
Length |
Comments |
Online format: This element and its attributes is included in the Online message. Batch format: This element and its attributes is included in the send, receive, detail, and footer type messages. |
source |
alpha |
25 |
Identifies the source of the XML message. |
target |
alpha |
25 |
Identifies the target of the XML message. OROMS indicates the XML message is sent to Order Management System. |
type |
alpha |
25 |
Identifies the type of information in the XML message. CWAuthorizationResponse indicates the message contains a response from the service bureau. |
mode |
alpha |
10 |
Indicates the mode of communication. Batch = Batch authorizations response. Online = Online authorizations response. |
type |
alpha |
10 |
Indicates the type of message in the batch. Online format: Detail displays. Batch format: Valid values: Header Detail Footer Send Receive |
action |
alpha |
10 |
Indicates if the authorization was successful. Complete Error Failed Receiving Response Rejected Sent Returned NotFound |
Online format: This element and its attributes is included in the Online message. Batch format: This element and its attributes is included in the detail type message. |
companyID |
alpha |
3 |
The company from where the authorization request was sent. Order Management System updates the CMP Company field in the Authorization History table. |
merchantID |
alpha |
20 |
merchantReference |
alpha |
20 |
A unique number made up of the Order Management System company code + order number + order payment method sequence number + authorization sequence number. The system uses this number to match the response to the appropriate transaction. For stored value card activations, the order payment method sequence number and authorization sequence number are always zero. Order Management System updates the CMP Company field, Order # field, OPM Seq # field, and AUH Seq # field in the Authorization History table. |
orderID |
numeric |
8 |
The order number where the credit card payment method that requires authorization is located. Order Management System updates the Order # field in the Authorization History table. |
paymentID |
numeric |
2 |
The order payment method sequence number for this credit card payment method on the order. Order Management System updates the OPM Seq # field in the Authorization History table. |
authID |
numeric |
3 |
The order payment method sequence number for the credit card authorization request. Order Management System updates the AUH Seq # field in the Authorization History table. For stored value card activations, updates the Activation date in the Stored Value Card table. |
ccAccountNumber |
alpha |
20 |
The card account number for the credit card payment method requesting authorization. This is the OPM credit card number field in the Order Payment Method table. If you use credit card encryption, the system encrypts the credit card number in the Order Management System database to provide additional security of credit card data. See the Data Security and Encryption Guide on My Oracle Support (1988467.1) for an overview. If you use credit card tokenization, the setting of the tokenized tag defines whether the number in the ccAccountNumber tag is the actual credit card number or a token provided by the authorization service. |
authNumber |
alpha |
7 |
The authorization number for the card. For stored value card reversals, if the VendorResponse1 tag is 100, the system loads a dummy authorization number in this field. Order Management System updates the AUH auth # field in the Authorization History table. |
authAmount |
numeric |
10.2 |
The authorized amount on the card, including decimals. Note: Stored value cards are only allowed in US currency. Order Management System updates the AUH amount authorized field in the Authorization History table. |
authDate |
numeric |
8 |
The date the credit card was authorized, in MMDDYYYY format. Order Management System updates the AUH auth date field in the Authorization History table. |
vendorResponse1 |
alpha |
10 |
The response for the credit card. Order Management System updates the AUH vendor response field in the Authorization History table. For stored value card activations, updates the Response code in the Stored Value Card table. |
vendorResponse2 |
alpha |
10 |
The credit card identification response for the credit card. Order Management System updates the AUH vendor response 2 field in the Authorization History table. |
avsResponse |
alpha |
10 |
The address verification response for the credit card. Order Management System updates the AUH AVS response field in the Authorization History table. |
fraudIndicator |
alpha |
1 |
Indicates whether the customer is a possible fraud. |
fraudScore |
alpha |
1 |
Future use value. |
actionCode |
alpha |
10 |
Indicates the type of transaction. Valid values: Activation = Stored value card activation. Balance = Stored value card balance inquiry. Authorization = Credit card, debit card, or stored value card authorization. Reversal = Stored value card authorization reversal. |
currentBalance |
numeric |
12 |
The current balance on the stored value card. Right justified, zero filled, with 2 implied decimals. |
previousBalance |
alpha |
12 |
The previous balance on the stored value card. Right justified, zero filled, with 2 implied decimals. |
authentication Response |
alpha |
10 |
The authentication response for the authentication verification value associated with the credit card. The authentication verification value is received from an authentication service, such as Visa’s Verified by Visa program or MasterCard’s SecureCode program, indicating whether the card authentication password the cardholder provided was approved for the credit card. See Credit Card Authentication Service for more information. This response is not stored in Order Management System. |
transactionID |
numeric |
16 |
A unique transaction ID assigned by the service bureau for the transaction. Updates the Transaction ID in the Authorization History table. Available in: 2.0 (release 2.5 of Order Management System). |
tokenized |
alpha |
1 |
Defines whether the number in the ccAccountNumber tag is the actual credit card number or a token. See Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1). Valid values: Y = The number in the ccAccountNumber tag is a token. N or blank = The number in the ccAccountNumber tag is the actual credit card number. Updates the Tokenized field in the Order Payment Method table. Available in: 3.0 (release 5.0 of Order Management System). |
Online format: This element and its attributes is not included in the Online message. Batch format: This element and its attributes is included in the send, receive, and footer type messages. |
fileType |
alpha |
4 |
Indicates the type of response. Valid values: MERC RESP AUTH BILL |
merchantFileTrace |
numeric |
3 |
Order Management System updates the ILC Reference ID field in the Integration Process Cntl table. |
rejectReason |
alpha |
60 |
Order Management System updates the ILC reference comment field in the Integration Process Cntl table. Included only if the authorization was declined by the service bureau. |
The Deposit Request XML message is used to send deposit requests to an external system when the Communication type field for the service bureau is Integration Layer.
Note: Order Management System does not currently support any base integration using an integration layer job and the Deposit Request XML Message (CWDepositRequest). Please contact your Order Management System representative if you wish to create a custom integration using this message.
Attribute Name |
Type |
Length |
Comments |
This element and its attributes displays for the header, detail, summary, footer, send, and receive type messages. |
source |
alpha |
25 |
Identifies the source of the XML message. RDC indicates the XML message is from Order Management System. |
target |
alpha |
25 |
Identifies the target of the XML message. |
type |
alpha |
25 |
Identifies the type of information in the XML message. CWDepositRequest indicates the message contains a deposit request. |
resp_qmgr |
alpha |
48 |
resp_q |
alpha |
48 |
Informational only |
This elements and its attributes displays for the header, detail, summary, footer, send, and receive batch messages. |
mode |
alpha |
10 |
Indicates the mode of communication. Batch indicates batch deposits. |
type |
alpha |
10 |
This element and its attributes displays for the header, detail, summary, footer, send, and receive batch messages. |
serviceID |
alpha |
3 |
Deposit service code. This is the ASV Auth service code field in the Authorization Service table. |
companyID |
numeric |
3 |
The company from where the deposit request was sent. This is the CMP Company field in the Authorization Service table. |
merchantID |
alpha |
20 |
merchantSubID |
alpha |
10 |
merchantName |
alpha |
20 |
merchantDivision |
numeric |
5 |
chargeDescription |
alpha |
20 |
receivingCode |
alpha |
10 |
startupInfo |
alpha |
10 |
signon |
alpha |
10 |
password |
alpha |
10 |
presentersID |
alpha |
10 |
pidPassword |
alpha |
10 |
submittersID |
alpha |
10 |
sidPassword |
alpha |
10 |
alpha |
5 |
A code that is assigned by the service bureau to identify your company type (DBA number). This is the ASV Industry format code field in the Authorization Service table. |
addressVerificationFlag |
alpha |
3 |
Indicates whether the service bureau performs address verification to verify the customer’s address and card number. YES = The service bureau performs address verification. The system includes the bill to name and address in the deposit request. NO = The service bureau does not perform address verification. The system does not include the bill to name and address in the authorization request. This is the ASV Address verification field in the Authorization Service table. |
This element and its attributes displays for the detail batch messages. |
companyID |
alpha |
3 |
The company from where the deposit request was sent. This is the CMP Company field in the CC Deposit Transaction table. |
createDate |
numeric |
8 |
The date (in MMDDYYYY format) the deposit request was sent to the service bureau. |
orderType |
alpha |
8 |
Indicates the type of order, for example phone order or mail order, where the card requiring deposit is located. Mail = Mail order. Phone = Telephone order. Internet = Web order. Order Management System: • looks at the value in the Internet order field in the Order Header table. If this field is set to I, the order is a web order. • determines if the order type for the order matches the E-Commerce Order Type (G42) system control value. If the order type matches, the order is a web order. • looks at the Forecasting order category field in the Order Type table. If this value is 1, the order is a mail order. If this value is 2, the order is a phone order. |
transactionType |
alpha |
10 |
Indicates whether the request is for a deposit or credit. Purchase = deposit. Return = credit/return. Conditional = authorize and deposit Note: Conditional deposit is not supported for stored value cards. |
merchantReference |
alpha |
20 |
A unique number made up of the Order Management System company code + order number + order payment method sequence number + authorization sequence number. This is the CMP Company field, Order # field, OPM Seq # field in the CC Deposit Transaction table and the AUH Seq # field in the Authorization History table. |
orderID |
numeric |
8 |
The order number where the credit card payment method that requires deposit is located. This is the Order # field in the CC Deposit Transaction table. |
InvoiceID |
numeric |
7.0 |
The invoice number associated with the credit card payment method. This is the Invoice # field from the CC Deposit Transaction table. |
paymentID |
numeric |
2 |
The order payment method sequence number for this credit card payment method on the order. This is the OPM Seq # field from the CC Deposit Transaction table. |
payCategory |
numeric |
15 |
A description of the pay category associated with the deposit request. Credit card displays, indicating the card is associated with the credit card pay category. This is the description associated with the Pay category field defined for the credit card pay type in the Pay Type table. |
vendorPaymentMethod |
alpha |
5 |
The vendor paytype code associated with the deposit request; this is the code the deposit service uses to identify a method of payment. This is the CPC vendor paytype/code field defined for the credit card pay type in the CC Paytype Cross Ref table. |
ccAccountNumber |
alpha |
16 |
The card number for the credit card payment method requesting deposit. If you use credit card tokenization, this number may be a token rather than the actual credit card number. This is the Credit card # field defined for the credit card payment in the CC Deposit Transaction table. If you use credit card encryption, the system decrypts the credit card number before sending it to the service bureau. See Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1) for an overview. |
expirationDate |
numeric |
4 |
The date the card requesting deposit expires. This is the OPM expiration date field defined for the card in the Order Payment Method table. |
depositAmountText |
numeric |
10.2 |
The amount on the card requiring deposit, including decimals. This is the Total $ amt field defined for the card in the CC Deposit Transaction table. |
depositAmount |
numeric |
10 |
The amount on the card requiring deposit, with implied decimals. This is the Total $ amt field defined for the card in the CC Deposit Transaction table. |
authID |
numeric |
3 |
The order payment method sequence number for the deposit request. If the authID is blank (indicating the record was never authorized), the system sends an action code of B (authorize and deposit). This is the Auth code field from the CC Deposit Transaction table. |
authDate |
numeric |
8 |
The date the card was deposited, in MMDDYYYY format. This is the Auth date field in the CC Deposit Transaction table. |
merchandiseDollars |
numeric |
10.2 |
The merchandise dollar amount requiring deposit. This is the Merchandise $ amt field defined for the card in the CC Deposit Transaction table. |
freightDollars |
numeric |
10.2 |
The freight dollar amount requiring deposit. This is the Freight $ amt field defined for the card in the CC Deposit Transaction table. |
additionalFreightDollars |
numeric |
10.2 |
The additional freight dollar amount requiring deposit. This is the Add freight $ field defined for the card in the CC Deposit Transaction table. |
totalTaxDollars |
numeric |
10.2 |
The total tax dollar amount requiring deposit. This is the Total tax $ amt field defined for the card in the CC Deposit Transaction table. |
gstTaxDollars |
numeric |
10.2 |
The GST tax dollar amount requiring deposit. This is the GST tax $ amt field defined for the card in the CC Deposit Transaction table. |
pstTaxDollars |
numeric |
10.2 |
The PST tax dollar amount requiring deposit. This is the PST tax $ amt field defined for the card in the CC Deposit Transaction table. |
additionalTaxDollars |
numeric |
10.2 |
The additional tax dollar amount requiring deposit. This is the Add tax $ amt field defined for the card in the CC Deposit Transaction table. |
handlingDollars |
numeric |
10.2 |
The handling dollar amount requiring deposit. This is the Handling $ amt field defined for the card in the CC Deposit Transaction table. |
currencyCode |
alpha |
3 |
The currency code used by the deposit service to define a currency. This is the CUR currency code field in the CC Deposit Transaction table. |
CIDNumber |
numeric |
4 |
Credit Cards The card identification number defined for the card. See Credit Card Security Service (CID, CVV2, CVC2). This is the OPM card security value field defined for the credit card payment method in the Order Payment Method table. Note: The card identification number is only available for online authorizations; once an order is accepted, the system removes the card identification number from the order, even if the order has not received an approved online authorization. Stored Value Cards The ID number assigned to the stored value card. Included only if an ID number is assigned to the card and a CID number does not exist. From the OPM SVC ID Storage field defined for the stored value card payment in the Order Payment Method table. |
CIDIndicator |
alpha |
1 |
The card identification indicator defined for the card, indicating if a CID number has been defined. Valid values: 1 = CID number is present on card. 2 = CID number is present on card, but is illegible. 9 = CID number is not present on card. This is the OPM card security presence field defined for the credit card payment method in the Order Payment Method table. |
issuingBank |
alpha |
10 |
This is the Issuing bank field defined for the payment method in the Order Payment Method table. |
alpha |
20 |
This is the OPM Checking account field defined for the payment method in the Order Payment Method table. |
checkNumber |
numeric |
9 |
This is the OPM Check number field defined for the payment method in the Order Payment Method table. |
routingNumber |
numeric |
9 |
This is the OPM Routing number field defined for the payment method in the Order Payment Method table. |
startDate |
numeric |
4 |
The start date of the debit card being processed, in MMYY format. This is the Start date field in the Order Payment Method table. |
issueNumber |
alpha |
2 |
The card issue number of the debit card being processed. This is the OPM card issue # field in the Order Payment Method table. |
firstName |
alpha |
15 |
The first name of the bill to customer defined for the card requesting deposit. This is the: • First name field in the Customer Bill To table, or • NAM First name field in the Customer Sold To table. |
lastName |
alpha |
25 |
The last name of the bill to customer defined for the card requesting deposit. This is the: • Last name field in the Customer Bill To table, or • NAM Last name field in the Customer Sold To table. |
addressLine1 |
alpha |
32 |
The street address of the bill to customer defined for the card requesting deposit. This is the: • Street address field in the Customer Bill To table, or • NAM Street address field in the Customer Sold To table. |
addressLine2 |
alpha |
32 |
The second address line of the bill to customer defined for the card requesting deposit. This is the: • Address line 2 field in the Customer Bill To table, or • NAM Address line 2 field in the Customer Sold To table. |
city |
alpha |
25 |
The city for the address of the bill to customer defined for the card requesting deposit. This is the: • City field in the Customer Bill To table, or • NAM City field in the Customer Sold To table. |
state |
alpha |
2 |
The state for the address of the bill to customer defined for the card requesting deposit. This is the: • State field in the Customer Bill To table, or • NAM State field in the Customer Sold To table. |
zip |
alpha |
10 |
The zip code for the address of the bill to customer defined for the card requesting deposit. This is the: • Zip field in the Customer Bill To table, or • NAM Zip field in the Customer Sold To table. |
country |
alpha |
3 |
The country code for the address of the bill to customer defined for the card requesting deposit. This is the: • RPR country field in the Customer Bill To table, or • RPR country field in the Customer Sold To table. |
alpha |
3 |
Represents either: • An electronic commerce indicator code, received from an authentication service such as Visa’s Verified by Visa program or MasterCard’s SecureCode program, indicating the level of security provided for a credit card transaction placed over the internet. • A value indicating if the order was placed on a web storefront. Valid values are: - YES = The order was placed over the web storefront. - NO = The order was not placed over the web storefront. From the Ecomm Indic field in the Order Payment Method table. If this value is blank, from the E-commerce indicator (Future use sts 1 field) in the Order Header table. |
authenticationValue |
alpha |
40 |
A code received from an authentication service, such as Visa’s Verified by Visa program or MasterCard’s SecureCode program, indicating whether the card authentication password the cardholder entered on the web storefront was approved for the credit card. See Credit Card Authentication Service for more information. From the Authentication value field in the Order Payment Method table. |
discountQualified |
alpha |
3 |
Indicates if the deposit is eligible for level II discounting. YES = The deposit is eligible for level II discounting. NO = The deposit is not eligible for level II discounting. A deposit is eligible for level II discounting if the Send Data for Level II Discounting (I12) system control value is selected, and: • the action code is B (conditional deposit), D (deposit), or R (refund). • the method of payment is MC (Mastercard), VI (Visa), or AX (American Express). • the credit card number falls within a range of numbers in the Level II Bin Range table. Note: To qualify, the number of positions in the level II bin range must match the number of positions in the credit card number. For example, if the credit card number is 4788250000121444, the level II bin range level must be 16 positions. |
authDateExpired |
alpha |
3 |
Indicates if the authorization date for the deposit has expired. YES = The authorization date for the deposit has expired. The system sends the service bureau an action code of B (authorize and deposit) and when a response is received, updates the Authorization History record with the new authorization number. NO = The authorization date for the deposit has not expired. The system uses the following calculation to determine if an authorization has expired: authorization date + reauthorization days = authorization expiration date This is based on the AUH Auth date field in the Authorization History table and the PAY Reauth days field in the Pay Type table. |
avsResponse |
alpha |
10 |
The AVS response received on the original authorization associated with the deposit. This is the AUH AVS response field in the Authorization History table. |
installmentMessage |
alpha |
18 |
The installment message defined for the flexible payment option deposit. The message contains the following: • DBA industry code (3 positions): the first 3 positions of the Industry format code for the authorization service. • Merchant ID message (11 positions): the Merchant ID message field for the pay plan. • Installment description (4 positions): for installment pay plans, this is a description of which installment was deposited, for example 1of4. For installment pay plans, the entire message is 18 positions. For deferred pay plans, the entire message is 14 positions. The system removes any space between the merchant ID and the installment description, for example: INSTALLMSG101OF02. |
purchaseOrder |
alpha |
15 |
The purchase order number associated with the deposit request. This is the Purchase order # field defined for the order in the Order Ship To table. |
reversalAmountText |
numeric |
10.2 |
The amount on the stored value card requiring authorization reversal, including decimals. This is the difference between the authorization amount and the deposit amount. For example, if the original authorization amount was $50.00 and the deposit amount is $30.00, the reversal amount is $20.00. Note: Stored value cards are only allowed in US currency. This field is populated only when the Perform Authorization Reversal during Deposit Processing (J20) system control value is selected and the authorization amount is greater than the deposit amount; see Stored Value Card Authorization Reversal. |
reversalAmount |
numeric |
10 |
The amount on the stored value card requiring authorization reversal, with implied decimals. This is the difference between the authorization amount and the deposit amount. For example, if the original authorization amount was $50.00 and the deposit amount is $30.00, the reversal amount is $20.00. Note: Stored value cards are only allowed in US currency. This field is populated only when the Perform Authorization Reversal during Deposit Processing (J20) system control value is selected and the authorization amount is greater than the deposit amount; see Stored Value Card Authorization Reversal. |
transactionID |
numeric |
30 |
The transaction ID for the authorization associated with the deposit request. From the Transaction ID field in the Authorization History table. |
tokenized |
alpha |
1 |
Defines whether the number in the ccAccountNumber is the actual credit card number or a token received from the authorization service during the credit card tokenization process. Valid values: Y = The number in the ccAccountNumber is a token. N = The number in the ccAccountNumber is the actual credit card number. From the Tokenized field in the Order Payment Method table. The system includes the tokenized tag only if the pay type is eligible for tokenization. Available in: 3.0 (Order Management System version 5.0). |
count |
numeric |
2 |
id |
alpha |
2 |
This element and its attributes displays for the header, summary, footer, send, and receive batch messages. |
fileType |
alpha |
4 |
Indicates whether the request is for a authorization and deposit or deposit. BILL indicates card deposit request. AUTH indicates card authorization and deposit request. |
merchantFileTrace |
alpha |
16 |
createDate |
numeric |
8 |
debitAmount |
numeric |
11.2 |
The net sales amount for this batch of deposit requests, with implied decimals. |
debitCount |
numeric |
9 |
The total count of sales records for this batch of deposit requests. |
creditAmount |
numeric |
11.2 |
The net refund amount for this batch of deposit requests, with implied decimals. |
creditCount |
numeric |
9 |
The total count of refund records for this batch of deposit requests. |
totalAmount |
numeric |
11.2 |
The total amount for this batch of deposit requests, with implied decimals. |
totalCount |
numeric |
9 |
The total count for this batch of deposit requests. |
alpha |
4 |
Indicates whether the deposit request is processed in a live (production) environment or in a testing environment. TEST = Testing environment. PROD = Production environment. This is the ASE Test mode field from the Authorization Service table. |
For each Deposit Request Message sent to the service bureau, the service bureau sends a Deposit Response XML message to Order Management System.
The Type attribute in the authorization response message identifies the type of message you are viewing in the batch (Send, Receive, Detail, Footer). A separate Detail type message is received for each deposit response in the batch.
Attribute Name |
Type |
Length |
Comments |
This element and its attributes displays for the send, receive, detail, and footer batch messages. |
source |
alpha |
25 |
target |
alpha |
25 |
type |
alpha |
25 |
Identifies the type of information in the XML message. CWDepositResponse indicates the XML message contains a deposit response. |
resp_qmgr |
alpha |
48 |
resp_q |
alpha |
48 |
mode |
alpha |
10 |
type |
alpha |
10 |
Indicates the type of message in the batch. Valid values: Header Send Receive Detail Footer |
action |
alpha |
10 |
Indicates if the deposit was successful. Complete Confirm Error Failed Receiving Response Rejected Sent Returned NotFound |
This element and its attributes displays for the detail batch message. |
companyID |
numeric |
3 |
The company from where the deposit request was sent. Order Management System updates the Company field in the CC Deposit History table. |
merchantID |
alpha |
20 |
The account number assigned by the service bureau to identify transmissions. Order Management System updates the Merchant ID field defined for the deposit service in the CC Deposit History table. |
merchantReference |
alpha |
20 |
A unique number made up of the Order Management System company code + order number + order payment method sequence number + authorization sequence number. The system compares the merchantReference against the Alpha order # field in the CC Deposit Transaction table to match a received deposit with a sent deposit record. Order Management System updates the Company field, Order # field, OPM seq # field, and Seq # field in the CC Deposit History table. |
orderID |
numeric |
8 |
The order number where the credit card payment method that requires deposit is located. Order Management System updates the Order # field in the CC Deposit History table. |
invoiceID |
numeric |
7 |
The invoice number associated with the credit card payment method. Order Management System updates the Invoice # field in the CC Deposit History table. |
paymentID |
numeric |
2 |
The order payment method sequence number for this credit card payment method on the order. Order Management System updates the OPM Seq # field in the CC Deposit History table. |
ccAccountNumber |
alpha |
16 |
The card number for the credit card payment method requesting deposit. If you use credit card tokenization, this number may be a token rather than the actual credit card number. Order Management System updates the Credit card # field in the CC Deposit History table. If you use credit card encryption, the system encrypts the credit card number in the Order Management System database to provide additional security of credit card data. See Credit Card Tokenization in the Data Security and Encryption Guide on My Oracle Support (1988467.1) for an overview. |
authNumber |
alpha |
10 |
The authorization code for the deposit. If the authorization number returned is NOTDEP or notdep, the system rejects the deposit. Order Management System updates the Authorization code field in the CC Deposit History table. |
AuthAmount |
numeric |
10 |
The authorized deposit amount on the card, with implied decimals. Order Management System updates the Deposit amount field in the CC Deposit History table. |
authDate |
numeric |
8 |
The date the deposit was authorized, in MMDDYYYY format. Order Management System updates the Deposit date field in the CC Deposit History table. |
vendorResponse1 |
alpha |
10 |
The deposit response for the card. Order Management System updates the Response code field in the CC Deposit History table. |
vendorResponse2 |
alpha |
10 |
The card identification response for the card. |
avsResponse |
alpha |
10 |
The address verification response for the credit card. |
fraudIndicator |
alpha |
1 |
Indicates whether the customer is a possible fraud. This is a future-use value. |
fraudScore |
alpha |
1 |
depositFlag |
alpha |
3 |
Indicates if the deposit was successful, based on the response code received back from the service bureau and an authorization number of NOTDEP. YES = The deposit was approved by the service bureau (the VendorResponse1 is 100 approved). NO = The deposit was rejected by the service bureau. |
authenticationResponse |
alpha |
10 |
The authentication response for the authentication verification value associated with the credit card. The authentication verification value is received from an authentication service, such as Visa’s Verified by Visa program or MasterCard’s SecureCode program, indicating whether the card authentication password the cardholder provided was approved for the credit card. See Credit Card Authentication Service for more information. Not stored in Order Management System. |
This element and its attributes displays for the send, receive, and footer batch messages. |
fileType |
alpha |
4 |
merchantFileTrace |
integer |
3 |
rejectReason |
alpha |
60 |
Order Management System updates the ILC reference comment field in the Integration Process Cntl table. Included only if the deposit was declined by the service bureau. |
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
