Processing Authorizations and Deposits Using Point-to-Point Communication
Purpose: Processing authorizations and deposits using point-to-point communication, allows you to post transactions directly to the service bureau in the format required by the service bureau.
Proxy server: When processing payment transactions, you can define a proxy server to act as an intermediary in order to increase security. Order Management System sends transactions to the proxy server and the proxy server sends the transactions along to the payment processor. The PROXY_HOST and PROXY_PORT properties in Working with Admin Properties (CPRP) allow you to define the IP address and port number used to connect to the proxy server during payment processing. If these properties are blank, the system does not route payment transactions through a proxy server and instead calls the payment processor directly.
Available Point-to-Point Integrations
Integration |
See: |
Oracle Retail Customer Engagement Stored Value Card integration: Allows you to process the stored value card transactions between Order Management System and Oracle Retail Customer Engagement in Oracle Retail Customer Engagement’s message format. |
Customer Engagement Stored Value Card Integration for an overview and more information on the Oracle Retail Customer Engagement messages used to process stored value card transactions between Order Management System and the Oracle Retail Customer Engagement system using point-to-point communication. |
Cybersource integration: Allows you to process token, authorization, authorization reversal, and deposit transactions between Order Management System and Cybersource in Cybersource’s message format. |
CyberSource Point-to-Point Integration for an overview and more information on the Cybersource messages used to process token, authorization, authorization reversal, and deposit transactions between Order Management System and the Cybersource system using point-to-point communication. |
For more information: See:
• Stored Value Card Integration for more information on how to process stored value card transactions.
• Processing Authorizations and Deposits using an Integration Layer Process for more information on processing authorizations and deposits using an integration layer process.
• Using the Credit Card Authorization Interface for more information on authorization processing in Order Management System.
• Processing Auto Deposits (SDEP) for more information on deposit processing in Order Management System.
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
