Topics in this part: This part describes integration between Order Management System and Order Broker.
• Order Broker Integration Overview describes the components of the integration between Order Broker and Order Management System, including the extract processes that occur automatically as well as the Order Broker and Merchandise Locator API’s, and describes required setup.
• Order Broker Integration provides details on how the integration with Order Broker handles each order type.
• Merchandise Locator API describes how to search for a store location where the customer can pick up an item.
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
