Allocation Element
The Allocation element allows configuration development to specify settings for allocations that move money into funds. This is used in conjunction with <AllocationFrom>.
| Element/Tag | Definition | Attributes | Element/Attribute Value and Description |
| <Allocation>
This is the start tag and end tag. This element is used if configuration
is different for the 'From' and 'To' funds. See FundAllocation
for details on configurable attributes.
Yes. If blank, will act as Yes. | |
| ALLOCATIONTYPES | Percent, Amount, PercentOfFund, Units - Define the available distribution format options for allocations. Comma-separated list. | ||
| ALLOWMIXEDMETHODS | Yes, No - Allows different method codes to be specified for each of the allocations moving money out. | ||
EXCLUDEFUNDFIELD |
String - Defines the value of the field or fund name to be included. |
| EXCLUDEFUNDFIELDVALUE | Yes, No | ||
| EXCLUDEFUNDNAME | Allows for a list of fund names that should not receive money. These fund names are separated by a comma. | ||
| EXCLUDEFUNDSTATUS | Yes, No - Excludes funds from being displayed based on fund status. | ||
| EXCLUDEFUNDSTATUSERROR | Yes, No | ||
| EXCLUDETYPE | Allows funds to be excluded from the allocations that are moving money into a fund, based on the type of fund. | ||
| FUNDLIMIT | Integer: Specifies the limit on the number of allocations that can take out money. | ||
INCLUDEFUNDFIELD |
INCLUDEFUNDFIELDVALUE |
Yes, No |
MIXEDALLOCATIONTYPES |
Mixed, Percent, Amount, Units - Define the available distribution format options when "Mixed" is chosen. Comma-separated list. |
SHOWVALUATION |
Yes, No |
XML Example
<Allocation EXCLUDETYPE='01,02,05' EXCLUDEFUNDNAME='Suspense,AIMFund'></Allocation>
<Allocation ALLOWMIXEDMETHODS='YES' FUNDLIMIT='18'> </Allocation>
<Allocation EXCLUDEFUNDSTATUS='01,02,03'></Allocation>
