Reference Documents
Refer to the official published document shown below for detailed information on Oracle Advanced Security, where it describes in detail how to configure and use the Secure Sockets Layer (SSL) and Transport Layer Security (TLS) protocols.
For Oracle 12c database: https://docs.oracle.com/en/database/oracle/oracle-database/12.2/dbseg/configuring-secure-sockets-layer-authentication.html#GUID-6AD89576-526F-4D6B-A539-ADF4B840819F
Difference between Secure Sockets Layer and Transport Layer Security
Transport Layer Security (TLS) is an incremental version of Secure Sockets Layer (SSL) version 3.0. Although SSL was primarily developed by Netscape Communications Corporation, the Internet Engineering Task Force (IETF) took over development of it, and renamed it Transport Layer Security (TLS).
Recommended TLS Version for SPMS
TLS 1.2 and above is the recommended protocol for SPMS.
Prerequisites
The Oracle database server version should be Oracle Database Enterprise Edition 12c Release.
On the application machine, Oracle Database 12c 32bit ODAC and 12c Client are required.
The Oracle public key infrastructure (PKI), which provides Oracle Wallet and Oracle Wallet Manager (OWM), is required. The OraclePKI command is used to create keys to generate certificates. The OraclePKI command can be found in $ORACLE_HOME/bin folder.
Using TLS for SPMS Clients and Oracle Database Connection
Transport Layer Security (TLS) can be used in a multi tenant environment for SPMS applications. If you want to use Transport Layer Security (TLS) in a multi-tenant environment for an SPMS application, then you must ensure that the database is able to use its own wallet with its own certificates for TLS authentication.
TLS works with the core Oracle Database features such as encryption and data access controls. By using Oracle Database SSL functionality to secure communications between clients and servers, you can:
use TLS to encrypt the connection between clients and servers.
authenticate any client or server, to any Oracle database server that is configured to communicate over TLS.
You must configure TLS 1.2 on the Oracle database server, and then the SPMS clients.
Configure TLS 1.2 on the Oracle Database Server.
Configure TLS 1.2 on the SPMS clients.
Log in to the Database Instance.
After you have completed the configuration, you are ready to log in to the database.
Step 1: Configure Oracle Wallet for Server (Database) Side
Open a command prompt window as a normal user.
Create a directory on the server machine to store the server wallet at <SERVER_WALLET>. Run the make directory command below at “C:/Oracle” folder.
>mkdir wallets >cd wallets >mkdir db >cd db
Based on the sample above, the value for <SERVER_WALLET> is “C:\Oracle\wallets\db”.
Create a wallet for the Oracle server. Create an empty wallet with auto login enabled:
> orapki wallet create -wallet "<SERVER_WALLET>" -pwd <password> -auto_login
Example: orapki wallet create -wallet "C:\Oracle\wallets\db" -pwd <password> -auto_login
Add a self-signed certificate in the wallet (a new pair of private/public keys is created):
> orapki wallet add -wallet "<SERVER_WALLET>" -pwd <password> -dn "CN=<server_machine_name>" -keysize 2048 -self_signed -validity <No. of Days>
Example: orapki wallet add -wallet "C:\Oracle\wallets\db" -pwd <password> -dn "CN=server1" -keysize 2048 -self_signed -validity 365
Check the contents of the wallet. Notice the self-signed certificate is both a user and trusted certificate.
> orapki wallet display -wallet "<SERVER_WALLET>" -pwd <password>
Export the certificate so it can be loaded into the client wallet later.
> orapki wallet export -wallet "<SERVER_WALLET>" -pwd <password> -dn "CN=<server_machine_name>" -cert <SERVER_WALLET>\<server-certificate-name>.crt
Example: orapki wallet export -wallet "C:\Oracle\Wallets\db" -pwd <password> -dn "CN=server1" -cert C:\Oracle\wallets\db\server-cert-db.crt
Check whether the certificate has exported to the above directory.
Step 2: Configure Oracle Wallet for Client (Application) Side
You must create a client wallet on all SPMS client machines. Follow the steps below to create a client wallet and repeat the steps on each of the database client machines.
Create a directory on the client machine to store the client wallet. Call it <CLIENT_WALLET>. Create it under the “C:\Oracle” folder.
>mkdir wallets >cd wallets >mkdir user >cd user
Based on the sample above, the value for <CLIENT_WALLET> is C:\Oracle\wallets\user
Create a wallet for the Oracle client. Create an empty wallet with auto login enabled:
> orapki wallet create -wallet "<CLIENT_WALLET>" -pwd <password> -auto_login.
> orapki wallet add -wallet "<CLIENT_WALLET> " -pwd <password> -dn "CN=<client_machine_name>" -keysize 2048 -self_signed -validity <No. of Days>
Ensure each client certificate has a unique name. Ue the client machine name as the certificate name.Check the contents of the wallet. Note that the self-signed certificate is both a user and trusted certificate.
> orapki wallet display -wallet "<CLIENT_WALLET>" -pwd <password>
Export the certificate, so it can be loaded into the server wallet later.
> orapki wallet export -wallet "<CLIENT_WALLET>" -pwd <password> -dn "CN=<client_machine_name>" -cert <CLIENT_WALLET>\<client-certificate-name>.crt
Ensure each client certificate has a unique name, use the client machine name as the certificate name.Check whether the certificate is exported to the above directory.
Step 3: Perform Clients-Server Exchange Certificate Process
These instructions are for the exchange server and client public keys. These steps must be repeated on each of the database client machines.
Copy <server-certificate-name>.crt from the server machine to the client machine <CLIENT_WALLET> folder.
Copy <client-certificate-name>.crt from the client machine to the server machine <SERVER_WALLET> folder.
Load the server certificate into the client wallet.
orapki wallet add -wallet "<CLIENT_WALLET>" -pwd <password> -trusted_cert -cert <CLIENT_WALLET>/<server-certificate-name>.crt
Check the contents of the client wallet. Note that the server certificate is now included in the list of trusted certificates.
Load the client certificate into the server wallet.
orapki wallet add -wallet "<SERVER_WALLET>" -pwd <password> -trusted_cert -cert <SERVER_WALLET>/<client-certificate-name>.crt
Check the contents of the server wallet. Note that the client certificate is now included in the list of trusted certificates.
Step 4: Configure the Oracle Database to Listen For TCPS Connection
Configure the listener.ora and sqlnet.ora files on the database server using the following steps.
To configure the listener.ora file:
Launch the Net Manager Tool.
Figure 1-1 Net Manager
Expand the Listeners container under Local, and select the Listener.
Click Add Address and select TCP/IP with SSL as the protocol.
Enter the hostname and port as shown in the screen below.
Figure 1-2 Listener, Address Tab
Click File, and then click Save Network Configuration to save the setting. Below is an example of the listener.ora file
LISTENER =
(DESCRIPTION_LIST =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = example.com)(PORT = <PORT NO>))
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCPS)(HOST = example.com)(PORT = <PORT NO>))
To configure the sqlnet.ora file using Oracle Net Manager:
Click Profile,and then select Network Security from the drop-down list.
Select the SSL tab, and then select the Server option.
Configuration Method: File System
Wallet Directory: <SERVER_WALLET>
Configure SSL for: Server
Revocation Check: NoneRequire Client Authentication: FALSE
Figure 1-3 Network Security in Net Manager
Click File, and then click Save Network Configuration to save. At this point, exit the Oracle Net Manager tool and ensure all changes are saved.
Since the Oracle Net Manager does not allow for certain values to be changed, open
<ORACLE_HOME>/network/admin/sqlnet.ora and make sure the following properties are set to
SSL_VERSION = 1.2 SSL_CIPHER_SUITES= (SSL_RSA_WITH_AES_128_GCM_SHA256)
In <ORACLE_HOME>/dbs/init.ora make sure the following property is set to
_use_fips_mode=FALSE
Restart the Database Service and listener so that all the above changes takes effect. From Windows Services Administrative Tools, Services, restart the corresponding Database Service. The Listener can be restarted from Windows services or as shown below:
Open the command prompt and follow the below steps using Run as Administrator:
> lsnrctl stop
> lsnrctl start
SQLNET.AUTHENTICATION_SERVICES=(BEQ,TCPS,NTS)
SSL_CLIENT_AUTHENTICATION = FALSE
SSL_VERSION = 1.2
WALLET_LOCATION =
(SOURCE =
(METHOD = FILE)
(METHOD_DATA = (DIRECTORY = C:/Oracle/wallets/db))
<ORACLE_HOME>/network/admin/listener.ora
WALLET_LOCATION =
(SOURCE =
(METHOD = FILE)
...To configure the tnsnames.ora file:
Click on Service Naming in Net Manager.
Click on Edit, select Create to create a new service. Complete the Net Service Name Wizard as described below:
Net Service Name: <Service Name>
Select: “TCP/IP with SSL (Secure Internet Protocol)”
Host Name: <Host Name>
Port Number: <Port Number>
(Oracle8i or later) Service Name: <Service Name>
Connection Type: Default database Test the connection on page 5 of the wizard.
Figure 1-4 Net Manager Service Name
Here is the sample tnsnames.ora file:
fidelio_tcps =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = TCPS)(HOST = example.com)(PORT = <Port No>)))
(CONNECT_DATA = (SERVICE_NAME = <Service_Name>))
Click File, and then clickSave Network Configuration to save.
Click File, and then clickExit. All server configurations have been completed.
Step 5: Configure the Oracle Client to Connect with TCPS Connection
Perform the following configuration on the machine running the SPMS application.
<ORACLE_HOME>/network/admin folder. File contents are similar to the example below.
SSL_VERSION = 1.2
WALLET_LOCATION =
(SOURCE =
(METHOD = FILE)
(METHOD_DATA = (DIRECTORY = C:/Oracle/wallets/user))
<ORACLE_HOME>/network/admin folder. Below are the sample file contents:
FIDELIO=
(DESCRIPTION =
(ADDRESS_LIST =
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = <Service Name>)
Connect to the Database using SQL*Plus client with SSL.
Launch the SQL*Plus session from the command line, by typing the username and password as <username>/<password>@ssl_connectstring.
To enable the IIS Server connection to the database, the wallet folder of the IIS server must give permission to IIS_IUSR to access the wallet. For further details, refer to the Oracle Database Security Guide, section “Configuring Secure Sockets Layer Authentication” located at: https://docs.oracle.com/database/121/DBSEG/asossl.htm#DBSEG9665.
