Query Based Data Element (QBDE)
A Query Based Data Element (QBDE) lets you view data from the Upper Form or Detail Form of a Business Process (BP). QBDE also lets you view data from:
- Other BPs
- Sheets
- Cash Flow
The QBDEs are based on the “SYS Numeric Query Based” Data Definition (DD), and the query for these QBDEs is set in the Business Process Configuration setup. For more information, see Configure a Query for a Query Based Data Element on a BP in the Unifier Essentials Modules Setup Administration Guide.
In addition to the Web interface (Unifier Essentials application in the browser), the system evaluates QBDE in the following areas:
- CSV import for record creation
- CSV import for Line Item creation
- Web Service methods for record creation along with Line items
- Web Service methods for Line Item creation
- Web Service methods for record updates
- Bulk Edit
- Bulk Update
- Creating BP records using BP
Notes:
- Because the system evaluates QBDEs in a random order, Oracle recommends that you do not create a QBDE that uses a formula that references another QBDE.
- DEs that have been defined as a QBDE trigger element should not be evaluated as part of QBDE calculation.
- Oracle recommends that you do not use a Required field to create a query that uses a Data Picker, Cost Breakdown Structure (CBS) Picker, or Fund Breakdown Structure (FBS) Picker. If the data entered in a data element (DE) field with a Required condition is cleared, the system bases the query on the previous value of the field.
- When using QBDE, be aware that query elements are rounded off to use two decimal places, even if the Base Currency and various defined currency fields are different.
Evaluating Query Setups of Data Picker Data Elements
The system supports many types of Data Picker DEs. The Administrator can set up Query conditions on these Data Picker DEs to filter the results. When a Data Picker DE is launched in the Web interface, the system runs the query and displays the records based on the queries defined. The system evaluates the data picker query conditions in the following areas, as well:
The following is a list of the supported Data Pickers:
- BP Data Picker
- Shell Data Picker
- User Data Picker
Note: If a BP Data Picker (BP Picker) or any Data Picker is selected as a trigger element for QBDE and the picker value is automatically populated (auto populated) instead of manually entered, the QBDE element will not be evaluated.
Creating a Record from the Query Based Tab
When creating a record from the Query Based tab of another BP (that auto-populates data to the record being created), the Data Element (DE) of type “SYS Numeric Query Based” Data Definition (any DE of this type) is not updated, unless the user manually changes the trigger element.
If a query condition involves only constant dates, it is not converted based on the user's time zone.
See Also
Using Formulas or Conditions in Queries
Assignee Filter Query Condition
Defining the Format of the Currency for QBDE
Last Published Tuesday, April 15, 2025
