How Queries Work
The way queries work in Unifier Essentials is as follows:
- You mine down to the information you want by choosing an element (field) in the database on which to base the query.
- You test the data against conditions and values that you specify.
A condition is a state or restriction that the value in the data element (field) must meet. A condition of the value might be that it must be equal to a certain number (for example, 10) or that it must contain a certain string of letters (such as "due date of").
- When (or if) the data meets the condition you specify, the system retrieves it from the database for use in a report, manager sheet, auto-creation, data picker, and so on.
See Also
Using Formulas or Conditions in Queries
Assignee Filter Query Condition
Query Based Data Element (QBDE)
Defining the Format of the Currency for QBDE
Last Published Tuesday, April 15, 2025
