Oracle Primavera Cloud Integration in Unifier Essentials Company
The Integrations grouping node lets the Company Administrators configure the connection details between Unifier Essentials and external applications. The Primavera Cloud functional node lets the Company Administrators configure the connection details between Unifier Essentials and Oracle Primavera Cloud application.
To access the Primavera Cloud Integration window:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Integrations, and then select Primavera Cloud to open the Primavera Cloud Integration page.
The Primavera Cloud Integration page has the following tabs:
- Connect tab
- Cash Flow Configuration tab
Recommended Integration Settings for Unifier Essentials and Oracle Primavera Cloud
To generate an access token for REST APIs, configure the OAuth client ID in Oracle Primavera Cloud. If you need additional support, contact your System Administrator.
You must have:
- Unifier Essentials integration permissions to establish a connection with Oracle Primavera Cloud.
- Valid credentials to access Oracle Primavera Cloud.
Removing a connection to an Oracle Primavera Cloud project
If you remove the link between Unifier Essentials and an Oracle Primavera Cloud project, you must also manually remove (unlink) the Project ID for the Oracle Primavera Cloud project from the Primavera Cloud Integration page.
In This Section
Connect for Oracle Primavera Cloud Integration
Last Published Tuesday, April 15, 2025
