Connect for Oracle Primavera Cloud Integration
Prerequisites: Refer to the Recommended Integration Settings for Unifier Essentials and Oracle Primavera Cloud section in the Oracle Primavera Cloud Integration in Unifier Essentials Company topic.
To generate a Lobby access token:
- In the Connect tab, enter the following:
- Primavera Cloud URL: Enter a valid Oracle Primavera Cloud URL to send and receive data between Unifier Essentials and Oracle Primavera Cloud. The URL must be identical to the one used for the host name of the Oracle Primavera Cloud.
- Username: Enter your email address.
- Password: Enter your Oracle Primavera Cloud password.
- To connect Unifier Essentials to the Oracle Primavera Cloud, click Save & Generate Access Token.
Notes:
- The refresh token is generated before the access token expires.
- If the server name and the host and scope name are different, the Oracle Primavera Cloud connection will not be established.
The system will use the access token (which is generated based on the user name and password) to authenticate the Oracle Primavera Cloud public API to send (push) and receive (pull) cash flow data for selected projects. If the values of the URL or credentials have been entered correctly, you will see this message: "The access token has been generated successfully." Otherwise, you will see this message: "The access token cannot be generated. Verify the credentials entered."
See Also
Last Published Tuesday, April 15, 2025
