Configuring Primavera Cloud Data Sources
CIC can be configured to display projects from multiple Primavera Cloud data sources.
To configure the properties for a Primavera Cloud data source:
- Sign in to the CIC Administration application from the Cloud Landing page of the Primavera Administration Application provided in your Welcome email.
http://<host>:<port>/cicadmin
- In the Home menu, select a staretl<id> or a <Custom Name of a data source>.
Note: <id> is the identifier of the data source.
- Click
Config in the sidebar for a selected Primavera Cloud data source. - In the Configurable Properties section, set the following properties, and then click Save.
Configuration Property | Description |
Custom Name for Datasource | Enter a name for the data source for identification purposes. For example, Primavera Cloud Production Data.
ODI Log Level | Controls the level of detail included in the ODI log files. Select any of the following values:
Spread Page Size | Enter the maximum number of assignments to be calculated for spread data. It controls the data volume the server handles in one request batch.
Primavera Cloud URL | This URL is preset for your organization and is used for detailed analysis.
Enable Loading Primavera Cloud Codes | Controls the ability to load codes. Select any of the following values:
Enable Loading Primavera Cloud UDFs | Controls the ability to load user defined fields (UDFs. Select any of the following values:
In the OBIEE Settings section set up the following properties: | |
Mail Prefix | Customize the text that will be displayed in the subject line of email notifications that are sent regarding the status of ETL runs. For example, enter Analytics for status updates on ETL runs.
Primavera CIC Host URL | The Primavera CIC Host URL is preset for your organization and is used for analysis.
Lobby URL | The Lobby URL is preset for your organization and is used to switch between applications accessible through the Smart Construction Platform.
OBIEE Cache Purge | OBIEE cache entries are used to as a method to improve response times of OBIEE dashboards. This property controls the clearance of OBIEE cache entries. Select any of the following values:
Send Email Notification | Enter the email IDs of the personnel to be notified regarding the status or issues with the STARETL runs. Also select the type of events for which they are to be notified:
Related Topics
Configuring Primavera Cloud Codes for Each Data Source
Configuring Primavera Cloud UDFs for Each Data Source
Last Published Friday, March 7, 2025
