Configuring Primavera Cloud UDFs for Each Data Source
To extract and load Primavera Cloud user-defined fields (UDFs):
- Sign in to the CIC Administration application from the Cloud Landing page of the Primavera Administration Application provided in your Welcome email.
http://<host>:<port>/cicadmin
- In the Home menu, select a staretl<id> or a <Custom Name of a data source>.
- In the left pane, select
UDFs. - Select any of the following tabs to migrate the corresponding UDFs or the selected data source:
- Activity
- Project
- Select any of the following sub-tabs to migrate a UDF type:
- Cost
- Date
- Non-Cost: Number and Integer UDF types are displayed in the 'Non-Cost' folders.
- Text
Notes:
- A maximum of 200 UDFs are supported for each area (Project, Activity) and data type.
- By default, CIC those UDFs that have been enabled in the CIC Administration application are exposed in the subject areas.
- To select a UDF to be migrated
- In the Available UDFs list, select a Primavera Cloud UDF you want to enable.
- Select Move Right.
- To deselect a UDF from being migrated
- In the Enabled UDFs list, select the UDF you want to remove.
- Select
Move Left.
- Select Save Changes.
Related Topics
Configuring Primavera Cloud Data Sources
Configuring Primavera Cloud Codes for Each Data Source
Last Published Friday, March 7, 2025
