CIC Analytics Application Setup Roadmap
CIC Analytics can be configured for projects managed and tracked in the following source applications:
- P6 EPPM cloud
- Primavera Unifier
- Oracle Primavera Cloud
- Oracle Aconex
To connect CIC Analytics with your source application, you have to setup the following applications as listed in the order listed below:
- The source applications you wish to connect with CIC Analytics listed above.
- CIC Analytics Administration application
The application setup roadmap illustrates the applications you need to setup to display projects in CIC Analytics.
Note: At this point in the setup sequence, you must have completed and configured your source applications if applicable (step 1). For more details, see Setting Up Source Applications for CIC Analytics.
Last Published Friday, March 7, 2025
