Configuration Settings for Aconex Data Source
CIC can be configured to display projects from multiple Aconex data sources.
To configure the properties for an Aconex data source:
- Sign in to the CIC Administration application provided in your Welcome email.
http://<host>:<port>/cicadmin
- From the
Home menu, select an Aconex data source. For example, select Staretl10 or Aconex_Staging. - Click
Config in the sidebar for a selected Aconex data source. - Set the following properties, and then click Save.
Configuration Property | Description |
Custom Name for Datasource | Enter a name for the data source for identification purposes. For example Aconex Production Data.
Aconex URL | This URL is preset for your organization and is used for detailed analysis.
Degree of Parallelism for Rebuild Index | If the Disable Rebuild Index property is set to False, then select the number of threads (CPUs) you want to enable to run in parallel to rebuild the index.
In the OBIEE Settings section set up the following properties: | |
Mail Prefix | Customize the text that will be displayed in the subject line of email notifications that are sent regarding the status of ETL runs. For example, STAR ETL email notifications for Aconex can be prefixed as CIC for Aconex ETL.
Aconex CIC Host URL | The Aconex URL is preset for your organization and is used for analysis. |
Lobby URL | The Lobby URL is preset for your organization and is used to switch between applications accessible through the Smart Construction Platform.
OBIEE Cache Purge | OBIEE cache entries are used to as a method to improve response times of OBIEE dashboards. This property controls the clearance of OBIEE cache entries. Select any of the following values:
Send Email Notification | Enter the email IDs of the personnel to be notified regarding the status or issues with the STARETL runs. Also select the type of events for which they are to be notified:
Related Topics
Selecting Aconex Project Fields for CIC Analytics
Configuration Settings for P6 EPPM Data Source
Configuration Settings for Unifier Data Source
Configuring Primavera Cloud Data Sources
Last Published Friday, March 7, 2025
