Assign status reviewers to a WBS to enable reviewers to view team member activity updates, make changes to the updates, and approve or reject the updates for the selected activities in the WBS.
You only need to perform this task if the required reviewers are not set at the project level or users with Admin or Project superuser privileges.
To assign status reviewers to a WBS:
- Click Projects.
- On the Projects navigation bar, click Activities.
- On the Activities page:
- Select a WBS.
- In the General detail window, double-click the Status Reviewer field.
Note: If the Status Reviewer field is not displayed, click
Customize Columns or Customize View and select Status Reviewer.
- In the Select Status Reviewers dialog box, select the reviewers and click OK.
- If the WBS contains child WBSs, you are prompted with a choice to assign the status reviewers to all child WBSs in the project. Choose Yes or No.
- Click Save.
Tips
- Team member status reviews must be enabled in Project Preferences to edit the Status Reviewers field.
- Status reviewers are set at the WBS level and apply to each activity included in the WBS. If a WBS includes child WBSs, the child WBSs will not inherit the status reviewers assigned to the parent.
