Reviewing Team Member Status Updates
Review updates your team members made to activities. While reviewing updates, you can modify the data, approve or reject the status updates, or place a hold on a status update to reconcile at a later time. You can view status updates for all projects that you are assigned as a reviewer, or choose to view status updates only for some projects.
Note: Only the fields updated by a team member using one of the P6 Team Member interfaces are displayed in the Status Updates page.
To view status updates:
  1. Click Approvals.
  2. On the Approvals navigation bar, select Status Updates.
  3. On the Status Updates page:
    1. Select whether to group the view by Resource, Review ,or None.
      You must be assigned the Admin Superuser or Project Superuser global security profile to group by review status.
    2. To see the assigned reviewers for a status update and the type of the review, select Reviewers.
Tips
Related Topics
About P6 Team Member Status Updates
Configuring P6 Team Member Status Update Reviews
Working with P6 Team Member Status Updates
Assigning a Status Reviewer to a WBS
Selecting an Activity for Review
Viewing Team Member Status Updates History
Configuring P6 Team Member View Preferences
Copyright © 1999, 2024
Last Published Thursday, July 25, 2024
