To delete a configuration or database instance:
- Select the configuration or database instance you want to delete.
- Right-click the configuration or database instance and select Delete.
Tips:
- You cannot delete the Factory Defaults configuration. You can delete any custom configuration, but not all of them. You must always have one custom configuration.
- You can delete any database instance associated with a configuration, but not all of them. Each configuration must have at least one database instance.
- You can delete the database that you specified during the database configuration. If you do so, you will need to run the Database Configuration wizard again. See About the Database Configuration Wizard for P6.
