Changing a Setting in the Primavera P6 Administrator
To change a setting value:
  1. Select either the Configurations or the Authentication tab to display a hierarchical view of the settings.
  2. Select a heading to display the settings.
  3. Select the field or the drop-down list that you want to change.
  4. Enter a new value.
  5. On the You have unsaved changes context menu, select Save Changes.
Related Topics
Reviewing and Modifying Configurations for P6
Returning a Primavera P6 Administrator Setting to its Default Value
Adding Configurations to the Primavera P6 Administrator
Adding Database Instances to a Configuration in the Primavera P6 Administrator for On-Premises
Deleting Configurations and Database Instances for P6 in the Primavera P6 Administrator for On-Premises
Exporting Configurations Using the Command Line for On-Premises
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
