Configuring P6 Team Member Web Settings
To configure the settings for P6 Team Member Web, you must have a P6 Team Member Admin Configuration. See Installing and Configuring P6 EPPM for more information on how to create this configuration during a new installation of P6 Team Member Web or P6 EPPM.
To configure the settings for P6 Team Member Web:
  1. Launch Primavera P6 Administrator.
  2. Navigate to your P6 Team Member configuration, and then expand it.
  3. Expand Application:
    1. Set the Help server URL to one of the following:
    • http://localhost:listenport/ContextRoot
      where localhost is your server's host name, listenport is your P6 Team Member port number, and ContextRoot is the root for your Help.
    • https://docs.oracle.com/cd/E90746_01/team_member/web/help/
      Note: Oracle recommends that you use the second URL option because it ensures that you always access the latest version of the P6 Team Member Help, including critical corrections and enhancements.
  4. Expand Team Member:
    1. Expand Connection Pool if you want to alter the following default values:
      • Initial connection pool size: 10
      • Maximum active database connections: 150
      • Maximum idle database connections: -0
      • Minimum idle database connections: 10
    2. Expand Logging if you want to alter the following default values:
      • Enable: enabled
      • Severity Level: Error
      • Log File Name: p6tmweb.log
        Note: The primavera.bootstrap.home property determines the location of the log file.
Related Topics
P6 Team Member Setup Tasks
Creating a New Primavera P6 Administrator Configuration
Configuring Email Statusing Service for P6
Configuring IIS 8.5 for P6 Team Member
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
