Configuring IIS 8.5 for P6 Team Member
To ensure that your instance of P6 Team Member works correctly with IIS 8.5, you will need to update your web.config file; otherwise, you might experience an error when attempting to select an option from the My Tasks drop-down list.
To configure IIS 8.5 for P6 Team Member:
  1. Navigate to %SystemDrive%\inetpub\wwwroot.
  2. Open web.config.
  3. Add <modules><remove name="WebDAVModule" /></modules> to the inside of the <system.webServer></system.webServer> tag.
  4. Add <remove name="WebDAV" /> beneath the <handlers></handlers> tag, which can be found inside the <system.webServer></system.webServer> tag.
  5. Save the file and the close it.
Related Topics
P6 Team Member Setup Tasks
Creating a New Primavera P6 Administrator Configuration
Configuring P6 Team Member Web Settings
Configuring Email Statusing Service for P6
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
