Assign project  codes and values
 - Choose Enterprise, Projects, then select the project to which you want to assign a code and value.
- Click the Codes tab.
- Click Assign.
- Select the project code value you want to assign.
 You can only assign one value per code.
- Click the Assign button, then click the Close button.
Tips
 - To change a code value assignment, double-click the code value you want to change and select a new code value.
- To remove a project code, select the code and value you want to remove in the Codes tab, then click Remove.
- You can view the assigned project codes in a column in the Activities and Work Breakdown Structure windows.
