- Choose Enterprise, Project Codes.
- Click Modify.
- Select the project code you want to edit.
 To change the project code's name, type a new name.
 To change the maximum number of characters the code's values may have, specify a new number.
 To change the placement of the code in the list, click Shift Up or Shift Down.
- Click Close.
Tip
- If you change a project code, your changes apply to all project assignments.
