- Choose Enterprise, Activity Codes.
- Choose EPS.
- Select the code whose value you want to change.
- To change a value or description, double-click the item you want to change, then type the new text.
 To change the placement of the code in the list, click the appropriate arrow.
- Click Close.
Tip
- If you change an activity code value, your changes apply to all activity assignments.
