Edit  EPS-level activity codes
 - Choose Enterprise, Activity Codes.
- Choose EPS, then click Modify.
- Select the activity code you want to edit.
 To change the code's name, type a new name.
 To change the maximum number of characters the code's values may have, specify a new number.
 To change the placement of the code in the list, click Shift Up or Shift Down.
- Click Close.
Tips
 - If you change an activity code, your changes apply to all activity assignments.
- Any code associated with an EPS-level you do not have access to, will appear under "No EPS ID". You can not modify or delete EPS-level activity codes listed under "No EPS ID".
