Use Work Product and Document Details to view and edit detailed information about and/or open the selected work product or document. You can also use Work Product and Document Details to assign the selected work product or document to work breakdown structure (WBS) elements and activities.
These are the available tabs:
- General tab - Work Product and Document Details
- Description tab - Work Product and Document Details
- Files tab - Work Product and Document Details
- Assignments tab - Work Product and Document Details
- UDFs tab - Work Product and Document Details
