The first step in the Lease origination process is entering credit application data into Oracle Financial Services Lending and Leasing Application. The Application Entry screen enables you to specify information from credit application into the system and request a credit bureau report.
This chapter explains how to use the Applications screen to specify and validate a credit application.
There are four main steps in entering an application
You can also enter credit application data into Oracle Financial Services Lending and Leasing Application using the Fax-In container. For more details, refer to ‘Application Entry using Fax-In’ section.
Once the basic details are entered, the user has to check whether the application pre qualifies or not. Once the pre-qualified edits are satisfied, click Submit in the Application screen. Pre-qualification edits can be viewed from the 'Verification' sub tab.
When finished, Oracle Financial Services Lending and Leasing checks the application for completeness using a predefined set of edits. These edits search for errors and warnings based on your system setup. Status change of the application can be determined by credit bureau and scoring model of the application. The prescreening checks ensure that automatic credit bureau reports are pulled only for applications which meet set criteria, thus saving cost.
After an application clears the edits check, click Process Application in the Applications section. The system begins the processes of prescreening the application and pulling a credit bureau while you can begin entering the next application in your queue.
To enter a new application
The Recreate Instance button appears only when the BPEL parameter is YES.
For details on this screen refer Applications section in Underwriting chapter.
Rental Agreement in OFSLL refers to a lease rental contract between financial institution and a customer. A lease rental contract is formed with mutual agreed terms and signifies a fixed rental amount that is paid by the customer for using an asset till the agreed term.
Rental based leasing option extends lease functionality to charge the customer with a fixed rental fee for the asset based on actual number of contract days for the defined cycle (i.e. Hourly, Daily, Weekly, and so on). Depending on the type of asset, rental leasing can either have only fixed rental or both rental and usage details. OFSLL supports the following types of rental based leasing:
The process flow to create a renting contract in the system differs a little for Existing and New type of customers and is explained in below sections separately.
Like any other application funding in Origination module, the lease renting contract is also moved through Application Entry, Underwriting and Funding process. But the Underwriting stage is automated and applications can be funded directly.
You can either start with Application Entry screen for creating renting contract or Scenario Analysis to simulate the same before creating.
In the Application Entry screen, you can search and select the existing customer details and the asset to be used for rental. Specify the required Term and Estimated amount for rental. Use the Renting Calculator to derive the rental amount based on the above details.
The status of such application will be in APPROVED -BLANK. The same can be accessed in funding screen and funded.
For a new applicant, the details are to be registered as a customer in the system. To do so, the applicant details are to be defined and funded against a contract.
While funding Loan and Lease contracts, the applicant information can also be processed along with other details. But for Line of Credit, you need to first create a line of credit application, assign a credit limit and fund the application. This process can also help to evaluate credit worthiness and also validate customer details against the KYC.
The same is indicated in the below image. The rest of renting contract processing is similar to existing customer workflow.
Whenever customer sends asset + usage details to OFSLL, the details are categorized to applicable rate slabs. Depending on the Charge Matrix, the rental + usage fee (if applicable) is calculated and charged on to the account. The same is communicated to the customer through account statement.
Following is an illustration on how system calculates non-tiered Rental bill.
The Rental matrix is as defined below:
Cycle |
Base Rental |
Discount % per Cycle |
Discount Amount per Cycle |
Cycle From |
Charge per cycle |
Weekly |
1 |
50 |
1 |
10 |
Weekly |
5 |
10 |
2 |
12 |
Monthly |
1 |
200 |
4 |
15 |
Monthly |
5 |
150 |
5 |
18 |
If only ‘Cycle From’ is defined and ‘Cycle To’ is not specified, then range is considered up to an infinite value or till the next defined cycle. Here the range for weekly cycle is between 1-5.
For Rental Amount, system will calculate the both 'Discount Amount' and 'Discount %' and deduct the minimum of these two values from the rental amount per cycle.
The calculation is as follows:
Account Cycle |
Account Term |
Calculation |
Rental Amount per Cycle |
After Discount |
Monthly |
3 |
200 |
200 minus (Minimum of (4% of 200 = 8) or 15) = 192 |
Monthly |
5 |
150 |
150 minus (Minimum of (5% of 150 = 10) or 18) = 194 |
Weekly |
2 |
50 |
50 minus (Minimum of (1% of 50 = 0.5) or 10) = 49.5 |
Note the following:
The Rental Agreement screen is a hybrid screen in Origination module which facilitates to capture and process most of the required action for funding rental based leasing contracts instead of navigating through multiple tabs.
Note
The Rental Agreement screen is available only for Lease Rental type of products and rental based leasing is supported for both ‘RENT FACTOR’ and ‘INTEREST RATE’ type of lease calculation methods in the system.
The ‘Rental Agreement’ tab consists of the following sub tabs:
The Rental Agreement tab is available next to ‘Summary’ tab in ‘Application Entry’ screen.
To create rental agreement
In this field: |
Do this: |
Existing Customer # |
Select the required customer from the drop-down list. The list is populated with all active customers maintained in the system. |
Existing Business # |
This field is enabled if the application type/class is ‘Business’. Select the Existing Business number from the drop-down list. |
Existing Asset # |
Select the rental asset from the drop-down list. The list is populated with list of assets maintained in ‘Collateral Management’ screen with Status - NEW, RELEASED, SOLD, INVENTORY, Collateral Type ‘Application Collateral’ and Lien Status ‘Undefined’. |
Asset Class |
View the asset class auto-populated based on the collateral type linked to application. |
Asset Type |
View the asset type auto-populated based on the Asset Class. |
Asset Sub Type |
View the asset sub type auto-populated based on Asset Type. |
Asset Status |
View the asset status auto-populated based on collateral status. |
Asset Description |
View the asset description auto-populated based on collateral details. |
Minimum Rental Cycle |
Select the minimum rental cycle to be considered for rental billing from the drop-down list. Starting from Hourly, you can select from a range up to Annually. |
Number of Cycles |
Specify a numeric value to indicate the total number of cycles to be calculated for the current rental. The same is based on the Asset Types configuration. |
Rental Start Dt |
Select the start date for rental agreement from the adjoining calendar. If the ‘Minimum Rental Cycle’ is ‘Hourly’, the current time stamp is also displayed. |
First Pmt Dt |
Select the first payment date based on billing cycle from the drop-down list. |
Rental End Dt |
View the rental end date auto-populated and calculated based on Rental Start Dt + First Pmt Dt + Billing Cycle. |
After populating the above fields, save the details. Click ‘Initialize’, system updates the Usage/Rental Details in the screen and are editable. Along with this, system also updates Usage Charge Matrix sub tab and Rental Charge Matrix sub tab details from the Asset Types Setup. Click ‘Calculate’ system auto-populates 'Rental Amount per Cycle' and 'Total Of Payments'. You can now process the rental lease application by clicking ‘Process Application’ button in Application header section. While processing, system auto assigns the matching pricing criteria and updates the application status to APPROVED - BLANK. Open the application in Funding tab and change the status to APPROVED - VERIFYING. |
Rental Options |
Instrument |
This field is enabled when an application is funded. Select the required Instrument from the drop down list. The list is populated with the available Contracts based on selected Pricing. In case the application stage is not 'Contract', system displays only NONE. Click ‘Load Instrument’ button. Note: An instrument is a contract with specific rules tied to it. An instrument associated with the application indicates OFSLL of the type of contract being used for the approved lease. Items defined in the contract are “locked in” when you select the instrument from drop down list and click on ‘Load Instrument’. These values cannot be changed on the funding screen. Any changes to the instrument in account will be handled by monetary/non-monetary transactions. |
Max Usage Allowed |
View / edit the maximum usage value allowed for the cycle. |
Security Deposit |
View / edit the security deposit amount paid upfront. |
Discount % |
View / edit the percentage of discount exempted from final billing. |
Discount Amt |
View / edit the flat discount amount exempted from final billing. |
Rental Amt Per Cycle |
View the system calculated value of Rental Amount per Cycle based on the rental charges. By default, system considers the minimum value derived by using Discount % or Discount amount during calculation. |
Total of Pmts |
View the system calculated value of Total of Payments based on rental charges and agreement duration. |
Excess Rent Collection Method |
View the type of Charge Matrix being used to derive the Excess Rent Collection Method as either ‘USING USAGE MATRIX’ or ‘USING RENTAL MATRIX’. |
Agreement Type |
Criteria |
Rental Matrix |
Usage Matrix |
Usage/Rental Details (based on Billing Cycle) |
Usage Rental |
Asset Type Asset Sub Type |
Base & Excess If the defined cycle is Hourly, matrix is based only on hours. For any other cycle, the same is not populated. |
Only Excess Populates only Billing Cycles Records |
Populates with same billing cycle record and application Agreement Type |
Rental |
NA |
Populates with same Billing cycle record and application Agreement Type |
The Itemizations sub tab enables you to add or verify any itemized amounts associated with the application. The list of itemizations is determined by the product you select in the master screen during the application entry process.
For rental based leasing contracts, itemization may consist of pre-paid fees like registration and so which can be configured and tracked within Rental Agreement > Itemization sub tab instead of maintaining it separately in Request tab.
For detailed information about Itemization and the process to add or view itemizations, refer to ‘Itemization Sub Tab’ in Request tab of Underwriting chapter.
The Usage Charge Matrix sub tab allows you to define and maintain different chargeable slabs based on the combination of Billing Cycle and Charge Type. The details maintained here are used for billing calculation based on a particular asset usage.
On clicking ‘Initialize’ in Rental Agreement section, the information in this tab is auto-populated based on details maintained in Asset Type setup. For more information about field details, refer to ‘Usage Charge Matrix’ section in Setup guides.
The Rental Charge Matrix sub tab allows you to define and maintain different chargeable slabs based on the combination of Billing Cycle, Rental Duration, Charge Per Cycle and Charge Type. The details maintained here are used for billing calculation based on a particular asset usage.
On clicking ‘Initialize’ in Rental Agreement section, the information in this tab is auto-populated based on details maintained in Asset Type setup. For more information about field details, refer to ‘Rental Charge Matrix’ section in Setup guides.
Using the information supplied on application, complete Applicants tab details and the following sub tab details:
The system uses the information on the Financial and Liabilities sub tabs in determining the applicant’s net worth. The system uses information on the Employments screen and Other Incomes sub screen to calculate the applicant’s debt-to-income ratio.
To complete the Applicants Details screen
For details on this screen refer Applicant Tab section in Underwriting chapter.
Oracle Financial Services Lending and Leasing can record SME business related financial information and business partners on the Business screen to assist in approving the Lease application during underwriting. The Business Applicant screen is available for Lease and contains the following sub screens:
To complete the Business Applicant screen
The Business tab appears on the Application Entry screen.
For details on this screen refer Business Tab section in Underwriting chapter.
Depending on the type of product you select, the following screen will be available from Requested link
To complete the request tab:
For details on this screen refer Request Tab section in Underwriting chapter.
The Master Account tab in Origination screen facilitates to categorize the current application to be considered as ‘Master Account’ after funding or link the current application to another existing master account in the system.
To define Master Account Details
For details on this screen refer Master Account tab section in Underwriting chapter.
The Bureau tab displays credit report (if pulled) for an applicant. If there is a need for another pull for any applicant, it can be done here manually using the New Request section.
To verify the credit bureau data using the Bureau tab
Click BureauFor details on this screen refer Bureau Tab section in Underwriting chapter.
Depending on the type of product or producer you select, the Collateral tab opens one of the three following collateral screen: a vehicle information screen, a home information screen or an other information screen. Complete the screen that is available on your Applications screen. After that, complete the Valuation and Tracking sub screen, which the Collateral link’s screens share. If you are entering an unsecured Lease, the Collateral link is present but inactive; in which case, skip this step.
To enter vehicle information from the Collateral tab
If the collateral is a home, the Collateral link displays information about the home.
If the collateral is any other, the Collateral link displays information about that collateral.
For details on this screen refer Collateral Tab section in Underwriting chapter.
When using the Application Entry screen, you can add comments to an application at any time in the application entry process by clicking the Tracking tab.
To complete the Comments screen
On the Application Entry tab, click Comments.
For details on this screen refer Comments Tab section in Underwriting chapter.
The Tracking tab enables you to record further information associated with the application. What items you choose to track are setup during implementation.
To track attributes
For details on this screen refer Tracking Tab section in Underwriting chapter.
Application Entry’s Documents screen enables you to view Application Documents and Application Documents Details.
For details on this screen refer Document Tab section in Underwriting chapter.
Oracle Financial Services Lending and Leasing can be configured to automatically validate portions of an application when you attempt to change its status. The results of this data check appear on the Verification link’s Edit screen as an Error, a Warning or an Override.
If it is an Error, the system will not allow you change the application’s status and approve the Lease until you fix all the errors.
If it is a Warning, the system enables you to change an application’s status without correcting the matter. While you should still investigate the problem, Warning messages are of a lesser importance than Error messages.
If it is an Override, the system displays a dialog box informing you that an override is needed; your responsibility level does not have the authority required to process this step. (Choose Yes on the dialog box to move application to queue of the user with required authority.)
To validate a credit application
For details on this screen refer Verification Tab section in Underwriting chapter.
The Tools tab calculates the payment amount, term, interest rate, Lease amount, amortization schedule and allows for the printing of a report.
For detailed information on using the tools, refer Tools chapter.
You can enter credit application data into Oracle Financial Services Lending and Leasing Application using the Fax-In image functionality using the Fax-In container. Once the all the images are loaded into the system using the steps mentioned in ‘Entering a Credit Application’ section, you can view those images in the Fax-In container and perform data entry concurrently.
The Fax-In container option is a simple image holder which is available to the user on clicking the ‘New Application’ button. The option is available only if has been enabled in the system settings by the administrator.
If you are the administrator, you can enable/disable this feature to the users in the access screen. However, you can view the availability of this feature by navigating to Main Menu > Setup > Administration > User > Access screen. Select Screen tab and in the Security Access Definition section, the status of “ACCESS TO MENU IMAGE MAINTAINENCE” flag defines the availability of this feature. If the flag is set to ‘Y’ then the Fax-In container is available in Application Entry screen.
The image container displays the image with the header information stored in the tables loaded as a part of the loading process. You can navigate through the pictures using the navigation buttons (First, Previous, Next and Last) available on the top right.
After entering the Application details, you need to select the Image check box placed on the top of Fax Image container. By doing so the system will automatically associate the current image with the application and save it along with the other application details. Also the image will no longer be available in the container since the container only holds those images which are not associated with any application.
The Review Request tab facilitates to flag an Application for the attention of another Oracle Financial Services Lending and Leasing user and ask for review / feedback. It allows the system users to send and receive requests (including e-mail) commenting on a specific account or application. The Review Request tab supports iterative review of selected Application and also to process the review with multiple reviewers.
For detailed information on using this feature, refer to ‘Review Request’ section in Underwriting chapter of the document.
