The following section lists all the resolved issues.
Table 3-1 Resolved Issues
| Product | Bug ID | Description |
SilverWhere .Net |
32370634 |
Resolved an issue in Layout Setup requiring at least one dining room table configuration with TABLE_TYPE = 'R' and CAPACITY>=2. |
SilverWhere .Net |
32946389 |
Resolved an issue in the Availability Grid affecting the sorting of the time in chronological order. |
SilverWhere .Net |
32970454 |
Corrected to display special characters in the First Name and Last Name columns in the All Reservations for Today @ X and All Reservation For Selected Period tabs on the Main Screen. |
SilverWhere .Net |
32989669 |
Resolved an incorrect date and time display in the Booked column in the All Reservations for Today @ tab that did require restarting the application. |
SilverWhere .Net |
24777526 |
Corrected the display in the Availability tab on the Main Screen to display only today and future days. |
SilverWhere .Net |
24776954 |
Corrected the display of availability type, Table or Guest, in Inventory Setup (née Alternate Availability Maintenance). |
SilverWhere .Net |
32421501 |
Resolved an issue to enable the deduction of the inventory for Walk In reservations in Product Setup. |
SilverWhere .Net |
31284037 |
Corrected the display of version number for the SilverWhere applications in Programs and Features. |
SilverWhere .Net |
29245615 |
Resolved an issue encountered when inserting LOOK_UP_VALUE=LOOK_UP_STATUS values in the LOOK_UP database table. |
SWReservation |
29723152 |
Resolved an issue to include the SWPARAM.XML file in the installation package |
SWMobile |
27242296 |
Resolved an issue in removing the SWMobile entry in Program and Features when uninstalling the application |
SW Database Installer |
26938907 |
Resolved an issue to create the WEBAUDIT table when starting the SW Database Installer |
GDF Configurator |
N/A |
Rebrand the application to Oracle Hospitality Cruise. |
GDF Configurator |
31432086 |
Resolved an issue in removing the EFC.ico file from the installation package. |
GDF Template |
33017886 |
Resolved an issue with the availability when creating the cruise via the GDF Interface. The default value for the ALTER_AVAIL.BASE_ID will now be ‘DEFAULT’ instead of NULL. |
