The GDF Configurator allows you to add or modify the GDF Templates that you use for data synchronization and data updates, using the available buttons and steps described below.
Editing a template
Select the GDF Template from the Template Overview tab and click Edit
Make the required change
Click Save
Click Compile
To verify if the GDF Template is running without errors, click on Run and all results will be displayed in the Output section
Deleting a template
Select the GDF Template from the Template Overview tab and click Delete
Confirm the deletion by clicking Yes
Copying or pasting a template
Select the GDF Template from the Template Overview tab and click Copy
Click Paste and this saves the GDF Template under a new name starting with ‘Copy from …’
Exporting a template
Select the GDF Template from the Template Overview tab and click Export
Browse to the location where you want to save the GDF Template.
Click on Save
Importing a template
Click Import in the Template Overview tab
Browse to the location where the GDF Template is stored, select the file with *.GDT extension and click on Open
In the Template Properties tab, configure the GDF Template. See section Configuration of the SWTOSPMS Template
Click on Save
Click the Compile button to verify if the GDF Template is running without errors, click on Run to display the results in the Output section. All GDF Templates are written and provided by Oracle Hospitality Cruise.
Starting or stopping a service
To start or stop the service of a GDF Template,
Click Start Service or Stop Service.
Registering or unregistering a template
To register a GDF Template,
Select the GDF Template from the Template Overview tab and click Register
This creates a registry entry for the GDF Template. In the Template Overview tab, the status of the GDF Template will change to Registered
To unregister a template, simply click Unregister. This removes the registry entry and changes the template in Template Overview to Unregistered.
Show Logs
To show the logs for a GDF Template,
Select the GDF Template from the Configuration of the SWTOSPMS Template tab and click Show Logs
In the Template Overview tab, Events section, you can review the logs shown
In order to see the full description of the logs, you can resize the windows using the drag and drop function on the divider between both windows, or adjust the column size for each field in the shown table.
Auto Refreshing Logs
To auto refresh the logs for a GDF Template,
Select the GDF Template from the Template Overview tab and click Auto refresh logs, select the GDF Template
This automatically refreshes the Events section.
Manual Refresh Logs
The Refresh Logs allow you to refresh the log information manually using the below steps.
From the Template Overview tab, select the GDF Template
Click Refresh logs
The Events section will be refreshed to show the latest logs
To save any changes within the GDF Template Properties, click on Save.
To compile the changes within the GDF Template Properties, click on Compile.
To open the GDF Template, click on Execute.
To stop the GDF Template, click on Stop Run.
To configure the number of rows being displayed in the Output section, click in the drop-down box for Output line.
To schedule the frequency to run the GDF Template, click on Schedule Item and define the days or minutes.
To add new Database Connection Details, click on Add Connection and provide the Connection Name, Instance Name, Database User and Database User Password.
To delete existing Database Connection Details, select the Database Connection from the drop-down menu and click on Delete Connection.
To validate if the Database Connection Details are correct and the connection to the database is successful, select the Database Connection from the drop-down menu and click on Test Connection.
