The Oracle Hospitality Cruise SilverWhere General Dynamic Interface (GDF) is a data integration tool that transforms data from one database to another, using the code base template to perform the transfer, compile and run each code during runtime.
Purpose
This document provides information about the functionalities of the Oracle Hospitality Cruise SilverWhere General Dynamic Interface (GDF).
Audience
This document is intended for installers, programmers, technical support teams, product specialists and others who are responsible for setting up the GDF Interface.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
November 2022 |
Initial publication. |
