General Functionalites
Before you begin, below are some standard navigation keys that you should familiarized yourself with as they may vary between the modules.
Refresh: To refresh the data within the setup form.
Clear Activity Log: To clear the data in the Activity Log tab.
The modules below are only accessible from the Group & FIT tab. This tab is only visible to users you have access to any of the functions and modules.
