In the Virtual Group Management module, you can add and modify Virtual Groups created for the selected dates on the Overview screen in the Date selection section. Virtual Groups are used to identify passengers traveling together, but not assigned to a group in the Shipboard Property Management System (SPMS) and SilverWhere. The Virtual Groups are only visible in SilverWhere and the group information is not synchronized with SPMS
Adding A Virtual Group
Select Virtual Group Management
Click Add Group and enter/ select the relevant information in the New Virtual Group pop-up window:
Group Name: The name of the Virtual Group.
Group Type: Pre-filled with SilverWhere.
Delegates: The number of passengers associated to the Virtual Group.
Seat Together: Check mark if the delegates want to seat together.
Don’t Seat: Check mark if the delegates wish to be seated separately.
Rotation: Check the applicable Rotation Code for this group (see Dining Rotation Setup)
Comments: Additional comments if applicable.
Editing A Virtual Group
Select the Virtual Group name and click Edit Group Info to display the Virtual Group Information
Make the required change and click Update Group Info
Deleting A Virtual Group
Select the Virtual Group name and click Delete Group
You can only delete a Virtual Group if no dining reservations are present for the group.Confirm the deletion
Selecting/ Deselecting All Group
You can select/ deselect all Virtual Groups with this function.
Click on Select/ Deselect All Group
Adding/ Removing Selected Guest
You can add/ remove the selected passengers from the Guest Search panel to a Virtual Group with this function.
From the Virtual Group Management, select the Virtual Group.
Select the passengers in the Guest Search Panel
Click on Add/ Remove Selected Guest
Adding/ Removing All Guest
You can add/ remove all passengers from the Guest Search panel to a Virtual Group with this function.
Select the Virtual Group and click on Add/ Remove All Guest
