The Itinerary Setup module allows you to add and modify the cruise templates being used in the Cruise Setup module.
Adding An Itinerary
Select Itinerary Setup
Select the ship to which the itinerary should be added to
Click Add Itinerary and enter the following information:
Days: Enter the duration of the itinerary
Description: Enter the unique name of the itinerary
Itinerary Daily Information section:
Day: The day of the itinerary will be displayed
Offset: Enter the offset time for this day, for example, 1 or -1
Itinerary: Enter the port of that day
Show Location: Enter SHOW to display the location of the show for that day
Show Name: Enter SHOW to display the name of the show for that day
Availability Template section:
Product: The name of the product will be displayed
Template: Select the Inventory Template from the drop-down menu
Click Save
Editing an Itinerary
Select the ship to which the itinerary belongs to
Select the itinerary that should be modified
Make the required change
Click Save
Copying an Itinerary
Select the itinerary and click on Copy Itinerary
Enter the name of the new itinerary
Click Save
Deleting an Itinerary
Click on Delete Itinerary and confirm the deletion
Fixing Missing Data
Click on Fix Missing Data to update the availability of the itinerary
