The Cruise Setup module allows you to add and modify the cruises for SilverWhere.
Adding a Cruise
Select Cruise Setup
Select the ship to which the cruise should be added to
Click Add Cruise and enter the following information in:
Details section:
Ship: The ship name will be automatically displayed
Cruise ID: Enter the unique ID for the cruise. Usually, it is a combination of the ship code (2 digits) and the embark date, e.g. OHYYYY-MM-DD
Embark Date: Select the start date of the cruise
Debark Date: Select the end date of the cruise
Description: Enter a description for the cruise if desired
Template: Select the template for the cruise if desired
Type: Select the cruise type from the drop-down menu:
R: Regular Cruise, e.g. 7 days cruise
S: Segment Cruise, e.g. 7 days cruise separated in two segments, segment A with 4 days and segment B with 3 days
W: World Cruise, only available in SilverWhere VB6 customer version
C: Continuous Cruise, only available in SilverWhere VB6 customer version
Seating Details section:
Dining Room: The dining room names will be automatically displayed based on the configuration in the Ship Setup module
Seating: The value will be automatically displayed based on the configuration in the Ship Setup module
Flex Seating Code: Enter the Flex Seating code for the dining room
Time: The value will be automatically display based on the configuration in the Look Up Setup module for SEATTIME1 and SEATTIME2 parameter
Itineraries section: The itineraries matching the duration of the cruise will be filtered automatically. Select the itinerary that should be applied to the cruise.
Itineraries Details section: The details of Itinerary will be displayed (as configured in Itinerary Setup) and the user can adjust them.
Click Save
Editing a Cruise
Select Cruise Setup
Select the ship to which the cruise belongs to
Select the cruise that should be modified
Make the required change
Click Save
Deleting a Cruise
Select Cruise Setup
Select the cruise
Click on Delete Cruise and confirm the deletion
You can only delete the cruise that is not currently selected and that does not have any active dining reservations.
