In the Look Up Setup module, you can add and configure the parameters for the SilverWhere application suite.
To expand the Look-Up Code Setup,
Click on the + (+ve) in front of Look-Up Code Setup to expand or – (-ve) to collapse the folder view
To search for Look Up Types
Select the Search tab and type in the Look Up Type you are looking for and click Search or press Enter
Matching results will be displayed
Clicking on the Look Up Type folder icon will display the parameters on the right section
Adding a Look Up Code
Select Look Up Setup
At the Main Menu tab, expand Look-Up Code Setup
Select the Look Up Type folder to add the parameter
Enter the following information in the Add New Look Up section. Consult the Consulting and Support team for guidance before adding a new entry
Code: Enter the code of the Look Up
Value Type: Select the value type of the Look Up
String Value
Boolean
Color
Numeric
Comment: Enter a comment if desired or provided by Consulting/ Support
Value: Enter or select the value (depending on the Value Type)
Click Add/ Edit to save the changes
Editing a Look Up Code
Select the Look Up Type folder and the results will be displayed on the right section of the module
Make the required change
Click Add/Edit to save the changes
Deleting a Look Up Code
Select the Look Up Type folder to which the parameter belongs and the results will be displayed on the right section of the module
Select the parameter, and all the details will be displayed in the Add New Look Up section
Click Delete and confirm the deletion
