General Functionalities
Before you begin, below are some standard navigation keys that you should get familiarized with and they may vary between the tools and modules.
Refresh: To refresh the data within the setup form.
Close View: To close the setup form. You may also click the ‘X’ button at the top right of the form.
Save: Save changes made to the form.
The tools and modules below are only accessible from the System Setup tab. This tab is only visible to users who have access to any of the functions and modules.
