This document describes the functionalities of the modules in the SilverWhere .Net application, System Setup tab.
Audience
This document is intended for application specialists and administrators of the Oracle Hospitality Cruise SilverWhere application suite.
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL: https://support.oracle.com
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
November 2022 |
Initial publication. |
