Configuring Cost Based Optimization Settings in the Database Instance Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator > Configuring Database Instance Settings for On-Premises > About Database Instance Settings
The cost based optimization settings will enable you to manipulate base SQL queries based on optimization statistics.
Caution: Do not alter these settings unless you are familiar with cost based optimization. Contact My Oracle Support for more information.
To set your cost based optimization settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Database/Instance[n]/Cost Based Optimization settings.
Note: Changes to these settings require you to restart the P6 server.
- Select Enable, to enable Cost Based Optimization. Leave the field clear to disable it.
- Select Dump Matching SQL, select to dump the SQL where a match is found in the QUERYLIB table for a given SQL statement.
Leaving the field clear to dump the SQL where a match is not found in the QUERYLIB table for a given SQL statement.
Note: To see these entries, you must set your logging level to INFO in Configuring Log Settings.
Related Topics
Configuring Driver Class and URL for Database Instance Settings
Configuring User Security for Database Instance Settings
Configuring Connection Pool for Database Instance Settings
Configuring Oracle WebCenter Content Core Capabilities (WCCC) in the Database Instance Settings
Configuring the Oracle Database Content Repository
Configuring CMIS-Compliant Content Repository in the Database Instance Settings
Configuring Session Settings in the Database Instance Settings
Configuring Oracle Analytics Publisher in the Primavera P6 Administrator
Configuring P6 to Connect to Oracle BPM
Configuring Import/Export Options (Scheduled Service)
Last Published Friday, February 2, 2024
