Configuring Import/Export Options (Scheduled Service)
To set your import/export options (Scheduled Service) settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations Database.
  3. Select your Instance from the drop-down list.
  4. Expand Import/Export Options (Scheduled Services).
  5. In the File Location field, enter the path you want the system to use for scheduled import and export jobs. All imports and exports, as well as all subfolders created or selected during scheduled jobs, are stored in the location specified in the File Location (Scheduled Service) field.
    Note: There are separate File Location (Scheduled Services) fields for each of your available P6 EPPM database instances. Each field can be modified or set in Database/Instance/Import/Export Options (Scheduled Services).
Related Topics
About Database Instance Settings
Configuring Driver Class and URL for Database Instance Settings
Configuring User Security for Database Instance Settings
Configuring Connection Pool for Database Instance Settings
Configuring Oracle WebCenter Content Core Capabilities (WCCC) in the Database Instance Settings
Configuring the Oracle Database Content Repository
Configuring CMIS-Compliant Content Repository in the Database Instance Settings
Configuring Session Settings in the Database Instance Settings
Configuring Cost Based Optimization Settings in the Database Instance Settings
Configuring Oracle Analytics Publisher in the Primavera P6 Administrator
Configuring P6 to Connect to Oracle BPM
Last Published Friday, February 2, 2024
